I'm interested in getting a new case to make my PC my friend gave me really mine, as all the internals have been upgraded at this point. I am torn on what case to get. Right now I am the most interested in NZXT's H510i but reviews on airflow make me wary.
Is this a good case decision? Or let me know what other great recommendations as well Around $130 budget for case.
https://linustechtips.com/topic/1102143-need-a-case/
32 minutes ago, BongoBrando said:
The Coolermaster H500 with it's 2 200mm fans is a pretty easy choice.
Used to be $99 though.
https://linustechtips.com/topic/1102143-need-a-case/#findComment-12872876
I'd encourage you to look at the Lian Li  011 Dynamic, it has a similar style, but much better airflow.
~Remember to quote posts to continue support on your thread~
-Don't be this kind of person-
CPU:  AMD Ryzen 7 5800x | RAM: 2x16GB Crucial Ripjaws Z | Cooling: XSPC/EK/Bitspower loop | MOBO: Gigabyte x570 Aorus Master | PSU: Seasonic Prime 750 Titanium
SSD: 250GB Samsung 980 PRO (OS) | 1TB Crucial MX500| 2TB Crucial P2 | Case: Phanteks Evolv X | GPU: EVGA GTX 1080 Ti FTW3 (with EK Block) | HDD: 1x Seagate Barracuda 2TB
https://linustechtips.com/topic/1102143-need-a-case/#findComment-12872877
