I finally got my system working with GUI Miner, and cgminer both, but I'm only getting around 280-290 kh/s with my 7870. Other benchmarks show that it should be closer to 400. Does anyone know what I can change to make it do so?
my .bat file is as follows
cgminer --scrypt -o stratum+tcp://stratum-us.doge.hashfaster.com:3339 -u username.username -p password -I 18 -g 1 -w 256 --thread-concurrency 15232
and my GUI Miner settings are 7870 (low usage)
I know it says low usage but when I go to high usage it crashes, and if I lower intensity, then I get less hashes than with low usage.
https://linustechtips.com/topic/110211-not-enough-hashes/
There are some setting that I can't remember (its been a long time since I mined) but there are difficulty levels or something like that.... I hope someone knows what its called.
My System Specs: (Short list) i7 4770k, GTX 780, many SSD's, a 2 TB HDD(deceased :( ), Corsair 650D. Full list: http://pcpartpicker.com/user/kchriz6097/saved/8dh7YJ
Upgrade Plan: Acquire some Black Noctuas then add 16 or 32GB of 2133MHz memory
https://linustechtips.com/topic/110211-not-enough-hashes/#findComment-1472176
Use CGminer rather than GUI miner. It's much better.
cgminer and guiminer are the same only guiminer has a grapic user interface.
CGminer is no longer supporting script
versions above 3.7.2 not more! version below yes!!!!
EOC folding stats - Folding stats - My web folding page stats
Summer Glau: Quote's The future is worth fighting for. Serenity
My linux setup: CPU: I7 2600K @4.5Ghz, MM: Corsair 16GB vengeance @1600Mhz, GPU: 2 Way Radeon his iceq x2 7970, MB: Asus sabertooth Z77, PSU: Corsair 750 plus Gold modular
My gaming setup: CPU: I7 3770K @4.7Ghz, MM: Corsair 32GB vengeance @1600Mhz, GPU: 2 Way Gigabyte RX580 8GB, MB: Asus sabertooth Z77, PSU: Corsair 860i Platinum modular
https://linustechtips.com/topic/110211-not-enough-hashes/#findComment-1472468
I was just stating the fact, I now use SG miner but still would like a faster hash rate for my 7870
I get 300kh/s on CGminer, SGminer, GUIminer
https://linustechtips.com/topic/110211-not-enough-hashes/#findComment-1472661
I get 400 on my 270  in SG miner
|Casual Rig| CPU: i5-6600k |MoBo: ROG Gene  |GPU: Asus 670 Direct CU2 |RAM: RipJaws 2400MHz 2x8GB DDR4 |Heatsink: H100i |Boot Drive: Samsung Evo SSD 240GB|Chassis:BitFenix Prodigy |Peripherals| Keyboard:DasKeyboard, Cherry MX Blue Switches,|Mouse: Corsair M40
|Server Specs| CPU: i7-3770k [OC'd @ 4.1GHz] |MoBo: Sabertooth Z77 |RAM: Corsair Vengeance 1600MHz 2x8GB |Boot Drive: Samsung 840 SSD 128GB|Storage Drive: 4 WD 3TB Red Drives Raid 5 |Chassis:Corsair 600t
https://linustechtips.com/topic/110211-not-enough-hashes/#findComment-1473318
