So my issue is that after a BSOD, my pc wont display image to monitor nor will my peripheals work/even light up, but pc turns on, cpu cooler, fans etc. After some reading I decided that I need to reset my cmos. My question is can i do so without a jumper, because my motherboard didnt come with one?
Pc specs :
Ryzen 5 3600
Asrock b450 pro4
16gb ddr4 3000mhz
Gtx 970
Seasonic focus plus 650w
https://linustechtips.com/topic/1101935-need-help-with-resetting-cmos/
I mostly use the CMOS pins. Shortcircuit them with a screwdriver or something. (First remove power cable and press the power button a few times to remove electricity from capacitators)
Then grab a screwdriver, and short-circuit the two pins. You'll find them in your motherboard's manual
Life is really challenging. I don't always suceed: )
