I have bought a pc with the following parts, I can't seem to get it to boot, or even power on.
  • Arctic Silver 5 High-Density Polysynthetic Silver 3.5 g Thermal Paste
  • Samsung 970 Evo 500 GB M.2-2280 NVME Solid State Drive
  • Asus GeForce RTX 2070 8 GB STRIX GAMING OC Video Card
  • Microsoft Windows 10 Home OEM 64-bit
  • Sceptre E255B-1658A 24.5" 1920x1080 165 Hz Monitor
  • Corsair K70 RGB MK.2 Wired Gaming Keyboard
  • Corsair DARK CORE RGB SE Wireless Optical Mouse
  • G.Skill Trident Z RGB 16 GB (2 x 8 GB) DDR4-3600 Memory
  • Thermaltake View 37 ATX Mid Tower Case
  • NZXT E 850 W 80+ Gold Certified Fully Modular ATX Power Supply
  • MSI MPG X570 GAMING PRO CARBON WIFI ATX AM4 Motherboard
  • AMD Ryzen 7 3800X 3.9 GHz 8-Core Processor
Here is the PCPP link, https://pcpartpicker.com/list/tyGGBb
Thanks everyone I got it fixed!
https://linustechtips.com/topic/1101438-help-needed-custom-pc-problems/
What messed me up on my first build (and still my only build) was not plugging in the 8 pin header, which I mistook as a GPU header but was actually for the motherboard.
If you can't get it to work, take it to a local computer shop, see if they can help. They can actually check over the PC, whereas we have to hope you aren't missing something
thx I will try this
