Storage Problem
By
Hydraengineer
in Troubleshooting
in Troubleshooting
Solved by Rainbow Dash,
Right-click on This PC and select manage:
Then go into disk management:
Find your new drive right-click on it and new simple volume. Or if a pop-up box appears, you can select the new drive to be GPT or MBR, personally I select GPT so I can partition it. But after that you need to find it and format it or new simple volume.
Issac Zachary ·
Posted in Troubleshooting2 -
4
PopsicleHustler ·
Posted in Audio4 -
4
4
Greasy_Pudding ·
Sveeno ·
Posted in LTT Releases8 -
4
thrasher_565 ·
Posted in Hot Deals0
play_circle_filled
Latest From ShortCircuit:
