You can tell us your budget and what you intend to use the PC for then we can make a suggestion list.
CPU: i7 8700 GPU: Asus ROG Strix GTX 1080 Mobo: Gigabyte Z370 Gaming 5 Ram: 16GB EVGA SuperSC SSD: Samsung 850 EVO 250GB
HDD: Seagate Barracuda 2TB PSU: TX650M Case: NZXT S340 Elite OS: Windows 10 Mouse: Logitech G403 Mouse Mat: HyperX Fury S Pro XL
Keyboard: CM Masterkeys Pro S (reds) Headphones: Sennheiser HD598 Monitor: Asus 24' MG248QR Devices: IPhone 11 Pro Max + 13' Macbook Pro
https://linustechtips.com/topic/110054-diy-pc-buying-guide/#findComment-1470305
Anyone know of a easy and good pc part buying guide bcz im a pretty big noob . Like you select what you want in a PC and it suggest parts or somthing. Or just a guide on general.
whats your budget and location?
Specs
https://linustechtips.com/topic/110054-diy-pc-buying-guide/#findComment-1470322
Ok thanks (: what forum would I post that in?
planing just scroll down on the main page
Specs
https://linustechtips.com/topic/110054-diy-pc-buying-guide/#findComment-1470393
