ok so right now i have a 1660TI a ryzen 5 2600 at 4.1GHz and a 24 inch acer 1080p 144 hertz monitor. i play doom 4 the witcher 3 shadow of the tomb raider and AC: Odyssey but i struggle to max out most of those games on high or ultra i wanna upgrade my cpu but im not sure which one is best?im open to both amd and nvidia i dont yet have a budget as ill be saving up for the card
https://linustechtips.com/topic/1100382-help-me-choose-a-gpu/
1 minute ago, Genwyn said:
So uhh, did you read OPs post at all or did you just read the title before making this comment?
Oh.......I read this part
https://linustechtips.com/topic/1100382-help-me-choose-a-gpu/#findComment-12858857
Since Shadow of the Tomb Raider and AC Odyssey are pretty CPU heavy, saving for a 3600 and 2060 super would be a good upgrade, or a 2070 super if you have the funds.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1100382-help-me-choose-a-gpu/#findComment-12858869
4 hours ago, OlympicAssEater said:
Here is my budget list
RX 580/590
GTX 1660TI
If you are rich......
RTX 2060 and above
GTX 1070/1080/1080TI  good used condition or new.
But we need to know your budget.
budget would be max 350 us
https://linustechtips.com/topic/1100382-help-me-choose-a-gpu/#findComment-12859294
On 9/1/2019 at 4:54 PM, 5x5 said:
Wait for next gen imo.
This is probably a good idea. Second to that is getting an AIB 5700 XT.
CPURyzen 7 5800X with Arctic Liquid Freezer II 120mm AIO & push-pull Arctic P12 PWM fans RAM: G.Skill Ripjaws V 4x8GB 3600 16-16-16-30
PSU: Be Quiet! Pure Power 12 M 1000W GPUASRock RX 5700 XT Reference with Eiswolf GPX-Pro 240 AIO & 2x Arctic P12 PWM fans Case: Antec P5
MotherboardASRock X570M Pro4 Monitor: ASUS ROG Strix XG32VC Storage: HP EX950 1TB NVMe, Mushkin Pilot-E 1TB NVMe, 2x Constellation ES 2TB in RAID1
https://hwbot.org/submission/4497882_btgbullseye_gpupi_v3.3___32b_radeon_rx_5700_xt_13min_37sec_848ms
https://linustechtips.com/topic/1100382-help-me-choose-a-gpu/#findComment-12861742
