I recently have expierienced some problems with my PC. When I am playing a game, which is running in 60 fps or higher, for, lets say, an hour, frame rate starts to drop to 40 fps or even lower. I noticed when that does happen, my GPU usage drops to 50% and even goes lower, while my CPU usage jumps to 100% and stays there. I have GTX 1660 and i5 7500. There could be a bottleneck, but im not sure about that. Also, im not playing CPU intensive games, like Battlefield 5. I have this CPU for about 2 months, and this GPU for roughly a month. When i put these two components together, there was no problems whatsoever. Is there anything I can do to fix this low GPU usage problem?
https://linustechtips.com/topic/1100211-low-gpu-usage/
Why did you buy a non HT cpu today?(you said 2 months ago, same shit) 4/4 is starting to lack nowadays enough ooempf.
What are your temps under load
MSI B450 Pro Gaming Pro Carbon AC | AMD Ryzen 2700x  | NZXT  Kraken X52  MSI GeForce RTX2070 Armour | Corsair Vengeance LPX 32GB (4*8) 3200MhZ | Samsung 970 evo M.2nvme 500GB Boot  / Samsung 860 evo 500GB SSD | Corsair RM550X (2018) | Fractal Design Meshify C white | Logitech G pro WirelessGigabyte Aurus AD27QD
https://linustechtips.com/topic/1100211-low-gpu-usage/#findComment-12857654
If your CPU usage is at 100% and GPU usage is less than 100%, thats an indication of a CPU bottleneck in your system.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/1100211-low-gpu-usage/#findComment-12857655
GPU is mostly around 67-74°C, CPU is 63-72°C. Buying this CPU was a mistake, and i dont doubt it. But my budget back then and right now is not good enough to buy a new motherboard and a new ryzen CPU.
https://linustechtips.com/topic/1100211-low-gpu-usage/#findComment-12857681
But can this problem occur after a while you had a pc? Right now i really didnt know if this problem is because of bottleneck, because, like i said, this problem started to occure 2 or 3 days ago.
https://linustechtips.com/topic/1100211-low-gpu-usage/#findComment-12857688
Did you check your GPU temp and power limit?
Gaming With a 4:3 CRT
System specs below
CPU: AMD Ryzen 7 5700X with a Noctua NH-U9S cooler
Motherboard: Gigabyte B450 Aorus M (Because it was cheap)
RAM: 32GB (4 x 8GB) Corsair Vengance LPX 3200Mhz CL16
GPU: EVGA GTX 980 Ti SC Blower Card
HDD: 7200RPM TOSHIBA DT01ACA100 1TB, External HDD: 5400RPM 2TB WD My Passport
SSD: 1tb Samsung 970 evo m.2 nvme
PSU: Corsair CX650M
Displays: ViewSonic VA2012WB LCD 1680x1050p @ 75Hz
Gateway VX920 CRT: 1600x1200@75Hz, 1200x900@100Hz, 960x720@125Hz, 800x600@140Hz
Gateway VX900 CRT: 1600x1200@75Hz, 1200x900@100Hz, 960x720@120Hz (Can be pushed to 175Hz)
Keyboard: Thermaltake eSPORTS MEKA PRO with Cherry MX Red switches
https://linustechtips.com/topic/1100211-low-gpu-usage/#findComment-12858086
Power limit- 100%
Temp. limit- 83 °C
Core clock- +0
Memory clock- +0
I am really lost now. I dont know what to do man. My cpu is always 100% and GPU reaches max 50%. Games are practically unplayable. I still refuse to believe that the problem is because of the bottleneck
https://linustechtips.com/topic/1100211-low-gpu-usage/#findComment-12858325
Maybe my GPU usage has gone to shit because of my PSU. Its not the best one, Corsair VS 450W. Maybe I should buy a new PSU and see if that helps, or is the problem definitely not in the PSU?
https://linustechtips.com/topic/1100211-low-gpu-usage/#findComment-12858451
@RazerzzWhat graphics settings you are using?
I'm using an i5-7400 with a GTX 970 and my play games just fine at mostly high to high detail.
Also you may have to clear the games cache sometimes.
System specs below
PSU: Corsair CX650M
https://linustechtips.com/topic/1100211-low-gpu-usage/#findComment-12859347
BFV IS a CPU intensive game.
It also performs worse now than it did months and months ago... closer to within 6 months of launch... to now.. a Decent amount of changes happened and performance isn't exactly better... likely worse in some cases.
Maybe it's just me using VHigh or Ultra... varied maps and situations..
4cores at 100% isn't abnormal for BFV.
4cores8threads hits 70-100% too and drops GPU usages.
Being thread limited does suck when you do come across games wanting more.
I'd be hunting a used i7, or save and sell the existing platform, paired with saved dollars and maximize a newer platform.
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
https://linustechtips.com/topic/1100211-low-gpu-usage/#findComment-12859365
