so i got a preety old case i love
and it has a 180mm case fan on it side to blow on the gpu (helps with temps pretty well from the 140mm i got sitted there right now)
and well...im a child...i want rgb xD
is there a argb/rgb fan that fits 180mm mount?
I know noctua has a 200mm that fits 180mm holes but it aint rgb and how will i get my 20% more power without RGB?!
well u got my mind....would love help with that
cpu: 5950x
mobo: asus tuf pro x570
gpu: 3090 FE
ram: 32gb G.SKILL Trident Z 3200 c14
psu: Antec HCP1300w Platinum (overkill i know...got it for a good price)
thats all needed right?...i didnt study for this exam....
https://linustechtips.com/topic/1099344-180mm-case-fan/
I dont think Cooler Master MF200R has 180mm holes, but you could just use cable ties to fix it in place.
Desktop benching:
https://linustechtips.com/topic/1099344-180mm-case-fan/#findComment-12851096
was thinking about it but i doubt it would work cus the holes for the 180 arent in the mash like the 140mm...they are like outside of it in solid metal so cable ties wont have a place to hand on...was thinking on a 180mm to 200mm adapter but not enough place for the gpu then...kinda sucks.
cpu: 5950x
gpu: 3090 FE
https://linustechtips.com/topic/1099344-180mm-case-fan/#findComment-12851166
