all prices taken from tweakers pricewatch
27 minutes ago, Niel_A said:
What build do you guys recommend for a 5700xt?
It also needs to run rainbow six on medium settings 1440p at stable 150+fps.
Thanks for the help
This is US pricing. What is your location ?
MSI B450 Pro Gaming Pro Carbon AC | AMD Ryzen 2700x  | NZXT  Kraken X52  MSI GeForce RTX2070 Armour | Corsair Vengeance LPX 32GB (4*8) 3200MhZ | Samsung 970 evo M.2nvme 500GB Boot  / Samsung 860 evo 500GB SSD | Corsair RM550X (2018) | Fractal Design Meshify C white | Logitech G pro WirelessGigabyte Aurus AD27QD
Im in Belgium west europe
motherboard is Dutch pricing, as no Belgium pricing available  on PCP
12 hours ago, Stormseeker9 said:
No problem, I have to check tweakers for better prices anyway. What do you think of "hello there 123"s build?
i think his build isn't bad but the motherboard isn't guaranteed to support the 3600 out of the box and i'm not really sure about the psu. If you want to save a bit you can get the case he suggested, for the rest i'd get what stormseeker suggested
My bad, OP can either choose a tomahawk max + ATX case for the 3600 or swap the 3600 with a 2600.
Upgraded CWT GPS platform. It's near the top (if you consider whisper m/rmx to be the top) but according to Stefan Payne the multirail config can cause issues on Vega. However the GPU i chose is the rx 5700 XT which is limited to 250W, so OP should be fine.
