MSI Afterburner fan speed at 0 but one fan still spins
Go to solution Solved by Niami,
4 minutes ago, Cyberspirit said:
I had the same issue and, if I remember correctly, you just need to enable the "Force fan speed update on each period" option in the settings.
  Reveal hidden contents
Nevermind, I turned off auto fan control and turned it back on and now they're both off
I have a GTX 1060 6GB (specifically GV-N1060WF2OC-6GD) and I use afterburner. Since the newest driver the card has been going down to 3 digit clock speeds allowing me to run fans at 0%. The fan speed is at 0 but one fan still spins, the one nearest to the IO, and the other isnt spinning at all. It does change speed otherwise but doesnt fully stop.
Make sure to quote or tag people, so they get notified.
  Hide contents
Tried it and its still spinning,
