Hello, so Its been one year I suffer like this and I think its time I stop. I have an Aurora R7 (Please don't tell me its bad or that I shouldve built it myself, I know about all of that thank you) And I've always had low fps with my pc which is not normal.
Here are my Specs:
Intel i7 8700 3.20 Ghz
I have 16 GB if Ram DDR4
NVIDIA GeForce GTX 1060 6GB GDDR5
I get like 30 fps at low-medium ish Graphics which I believe it isn't normal. My Monitor is a 60 Hz and its connect via HDMI to my Card(I believe.. its my first ever gaming pc)
At the current time writting this with Chrome and an Anti-Virus Opened in Background, My Task Managers shows this:
CPU - 5%
Memory - 35%
Disk 4%
Maybe its a memory issue? Its very probable its also a configuration problem since this is my first pc aswell.
I am in mode performance in windows settings(Instead if balanced mode)
I have my drivers up to date
I have disabled the included graphic card coming with it (Intel, i thought this was my problem)
Its really annoying.. I dont know how I have lived with it for so long.. I hope someone can help me outhere.. My last resort would to erase my whole pc and install a game to see if it works fine that way, but I honestly wish I can find something wrong before that, and maybe it could also been like i said a configuration problem..
All Drivers Are Up to date
Speccy:
User Benchmark:
https://linustechtips.com/topic/1099068-low-fps-for-my-specs/
First I'd make sure if you're actually connected to the graphics card. That would 100% be the issue if so.
If it's all good, use DDU and reinstall your video drivers
CPU: R5 3600 || GPU: RTX 3070|| Memory: 32GB @ 3200 || Cooler: Scythe Big Shuriken || PSU: 650W EVGA GM || Case: NR200P
https://linustechtips.com/topic/1099068-low-fps-for-my-specs/#findComment-12848594
It is indeed connected to my graphic card, Ive made research, Ill try DDU and see if it helps, Ill come back if it doesnt
https://linustechtips.com/topic/1099068-low-fps-for-my-specs/#findComment-12848603
Here are my Specs:
CPU - 5%
Memory - 35%
Disk 4%
Speccy:
User Benchmark :
https://linustechtips.com/topic/1099068-low-fps-for-my-specs/#findComment-12848631
Here are my Specs:
CPU - 5%
Memory - 35%
Disk 4%
Speccy:
User Benchmark:
You should do a fresh install of windows. Linus made a video series some months ago ($1500 Gaming PC Secret Shopper) and he reviewed the same machine you have, they found some performance issues regarding the software installed on the machine and a clean install solved the problems.
I will leave the final episode here:
https://linustechtips.com/topic/1099068-low-fps-for-my-specs/#findComment-12850012
