Hi, my friend wants to build a new gaming pc without breaking the bank. There price range is about $300-500, and are mainly looking to play a AAA titles such as Overwatch. They are also switching from Mac to windows and will most likely need a new monitor since they have one that runs on 780p, you don"t have to include the windows key since I have many unactivated one lying around. Thanks :)))))
https://linustechtips.com/topic/1098698-help-for-a-friend/
This in conjunction with the best GPU you can get off eBay with the remaining funds would do quite nicely. I would personally suggest using the current monitor, even though it's crap, and buying a better one down the line if the appearance is not suitable.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1098698-help-for-a-friend/#findComment-12845769
Welcome to the forums!
We can definitely do something for your friend. You have two options. One is to look for used hardware. If you love PC building and bargaining, it's the best option.
If you must buy all-new, what I suggest is to grab a Ryzen 5 CPU with an integrated graphics processor. The GPU in it is good for Overwatch at medium settings, 1080p which is fine for entry level, and the CPU is strong enough that you can slap in a graphics card later and enjoy a huge boost in performance.
If you went, all new, this is my suggestion. Give your friend the following build, then have him save up about $100 more and buy an RX 570 which is a card that will give him a huge boost in gaming performance for cheap.
PCPartPicker Part List
CPU: AMD Ryzen 5 2400G 3.6 GHz Quad-Core Processor  ($119.69 @ Amazon)
Motherboard: ASRock B450M-HDV R4.0 Micro ATX AM4 Motherboard  ($64.99 @ Amazon)
Memory: *Crucial Ballistix Sport LT 16 GB (2 x 8 GB) DDR4-3000 Memory  ($59.99 @ Amazon)
Storage: ADATA Ultimate SU800 512 GB 2.5" Solid State Drive  ($57.99 @ Amazon)
Case: Cougar MG110 MicroATX Mini Tower Case  ($37.99 @ Amazon)
Power Supply: SeaSonic S12III 450 W 80+ Bronze Certified ATX Power Supply  ($45.99 @ Amazon)
Monitor: HP VH240a 23.8" 1920x1080 60 Hz Monitor  ($109.99 @ Amazon)
Total: $496.63
Generated by PCPartPicker 2019-08-27 19:40 EDT-0400
You are welcome to tweak the build to your liking, but keep in mind a couple things:
Try to keep the fast, 3000MHz RAM. Integrated graphics processors like the one on the Ryzen 2400G rely on your system RAM to use as video memory, so an increase in its speed is significant in terms of performance.
There are a lot of low quality, almost dangerous power supplies that go around for cheap. That one there is the cheapest I could find that will not give you problems.
You could go with a smaller SSD and save about $30. If you do that, you will find yourself running out of space in a couple months, at that point you can buy a hard drive or even a bigger SSD to throw in there. There's no reason to use hard drives nowadays since SSDs are between 10 and 50 times as fast, and only cost twice as much per GB.
Let us know what you think :)
~Energycore
P.S. I'll have to ask @LukeSavenije, our resident Seasonic critic, what he thinks of the S12III model. I'm almost 100% confident it will do you well. But he's the real expert on when not to choose Seasonic, an otherwise excellent brand.
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
https://linustechtips.com/topic/1098698-help-for-a-friend/#findComment-12845819
Total: $496.63
~Energycore
Hi, thank you for your help. I was wondering if it would be fine if i were to change the ssd to a 250gb one and use the scraped money to put a Ryzen 5 2600 instead of the 2400G, and just give them a tb hard drive they can move the games onto
https://linustechtips.com/topic/1098698-help-for-a-friend/#findComment-12845836
no bueno to me. just because it's individually regulated doesn't mean it's good
it uses the ancient dual mag amp, which needs a load and is less efficient than dcdc
evga gd seems like a decent option, something by fsp that reminds me of the pure power 11
and your motherboard taste isn't good either so far... swap for a pro4
https://linustechtips.com/topic/1098698-help-for-a-friend/#findComment-12845837
The problem with the Ryzen 5 2600 is that it doesn't have integrated graphics. So you'd have to buy a graphics card, which increases your friend's initial investment.
If your friend doesn't mind going $120 higher, have him grab a 2600 and an RX 570.
I get where you're coming from, but as someone who has in the past made some very tight budget builds, every penny is worth saving and features / performance of a decent motherboard aren't that needed if the budget conscious gamer doesn't go overclocking on a cheap af mobo :)
EDIT: forgot the most important part: can you find a better PSU below $50? Cuz I remember the CX450M being as cheap as $20 as little as a year ago
Computer Specs:
https://linustechtips.com/topic/1098698-help-for-a-friend/#findComment-12845847
Thats a good thing to know, i'll prob just get them a early birthday present and surprise them with a VEGA 56 since there is a new one in my area that someone is selling for $200...would that be good?
https://linustechtips.com/topic/1098698-help-for-a-friend/#findComment-12845863
let me put it like this... I'd trust a pro4 with a 3900x with a fan on it
and wouldn't even want to try a 2600 on a hdv 4.0
well, gd seems to be somewhat decently priced rn
it was... but PSUs took a weird jump with all the Chinese-American stuff going on
well, I'm here now already, time for magic
https://linustechtips.com/topic/1098698-help-for-a-friend/#findComment-12845867
Why is the GD not showing up on my version of pcpp...
I derped. I set amazon as only merchant and forgot to switch.
I'll switch the monitor though. Ew, TN panel.
CPU: AMD Ryzen 5 2600 3.4 GHz 6-Core Processor  ($131.19 @ Amazon)
Motherboard: ASRock B450M PRO4 Micro ATX AM4 Motherboard  ($79.38 @ OutletPC)
Memory: *OLOy 16 GB (2 x 8 GB) DDR4-3000 Memory  ($57.99 @ Newegg)
Storage: SanDisk SSD PLUS 240 GB 2.5" Solid State Drive  ($33.99 @ Amazon)
Power Supply: EVGA GD (2019) 500 W 80+ Gold Certified ATX Power Supply  ($45.98 @ Newegg)
Total: $496.51
Generated by PCPartPicker 2019-08-27 20:24 EDT-0400
@HUExGxRECTION how's this? + the Vega 56.
Computer Specs:
https://linustechtips.com/topic/1098698-help-for-a-friend/#findComment-12845879
I'm way too bored for this
sorry?
https://linustechtips.com/topic/1098698-help-for-a-friend/#findComment-12845884
sorry?
We have ourselves a winner!
You know in my younger days I would have competed, but that build looks très excellent
Computer Specs:
https://linustechtips.com/topic/1098698-help-for-a-friend/#findComment-12845886
Just now, LukeSavenije said:
you're getting old?
maybe time to refresh everything and finally set up your discord?
Gosh, I need to get around to that.
Anyway, let's not spam OP with notifications anymore ?
Computer Specs:
https://linustechtips.com/topic/1098698-help-for-a-friend/#findComment-12845891
sorry?
This looks perfect, although im quite surprised that you put in the OLOy memory since most would suggest the Crucial Ballistix Sport LT...thank you both for the help ?
https://linustechtips.com/topic/1098698-help-for-a-friend/#findComment-12845896
crucial is technically micron, but i just used @Energycore's filter on the cheapest 3000 mhz kit
https://linustechtips.com/topic/1098698-help-for-a-friend/#findComment-12845899
6 hours ago, HUExGxRECTION said:
I'll recommended something like this instead...
@LukeSavenije, what do you think about this??.
CPU: AMD Ryzen 5 2600 3.4 GHz 6-Core Processor  ($133.00 @ Amazon)
Motherboard: ASRock B450M Pro4-F Micro ATX AM4 Motherboard  ($71.00 @ Amazon)
Memory: OLOy 16 GB (2 x 8 GB) DDR4-3000 Memory  ($57.99 @ Newegg)
Storage: PNY CS900 240 GB 2.5" Solid State Drive  ($29.99 @ Amazon)
Case: DIYPC MA01 MicroATX Mini Tower Case  ($19.98 @ Newegg Business)
Monitor: MSI Optix G24C 23.6" 1920x1080 144 Hz Monitor  ($149.99 @ Newegg)
Total: $507.93
Generated by PCPartPicker 2019-08-28 01:37 EDT-0400
Plus the Vega 56 that you were planning on getting.
SSD TIER LIST
CPU - Ryzen 7 3700X
Mobo - ASRock X470 Taichi
Memory - G.Skill Trident Z RGB (8x2 3200MHz)
Storage - Sabrent Rocket 1TB - Seagate Barracuda 2TBWD Black 1TB
GPU - MSI GeForce GTX 980Ti LIGHTNING
CaseFractal Design Meshify C
PSUSuper Flower Leadex II Gold 650W
https://linustechtips.com/topic/1098698-help-for-a-friend/#findComment-12846297
similar, just more on the monitor and less on storage
I'd rather put a 144hz monitor with a Vega 56
SSD TIER LIST
CPU - Ryzen 7 3700X
https://linustechtips.com/topic/1098698-help-for-a-friend/#findComment-12846311
