Hello, I has a Topping D50, with my PC as usb input, and output through RCA to an RCA switcher which is connected to my HomeTheater through RCA input and to my WH1000XM3 through RCA to 3.5mm cable.
I also has a Samsung Note 8 which I would like to use to stream music through Bluetooth (aptx HD or Samsung UHQ) to Topping D50 and use it as a DAC while outputting to either HomeTheater or headphone. I know that Topping D50 (not D50s) doesn't has a Bluetooth capability. I know that I can just connect my phone to my wh1000xm3 through Bluetooth but it seems to be a waste not to use the D50 as a DAC and turning on the wh1000xm3 as an amplifier while still connected to the dac through wire.
So my question is, is there a device that receives Bluetooth audio and output it without converting the data to analog first as optical, coaxial, or USB? So that I can input it to the dac?
I don't think thatsuch a device will do you much good. But the taitronics sender may be what your looking for. Aptx and LDAC is basically the best we can get right now for Bluetooth audio. I would say getting a nice amp like ajds labs atom and a wired  headphone is worth it.
