Hey everyone! Around 5 months ago Ive managed to build myself a pc and had 2 problems. On my old motherboard there were 2 sockets One was a Msata socket and the other one was a Mini-Pcie socket (someone on this forum told me that). Also they told me those sockets look identical but have different functions. My ssd was a Msata so I bought an adapter (Msata to sata) on amazon and it works flawlessly. Now I have a Asrock b85 dash/ol motherboard which sadly has neither Msata or mini pcie slots so my question is. Is there anyway I can buy an adapter for this WiFi/Bluetooth card?
Thanks in advance you guys.
https://linustechtips.com/topic/1098157-wifi-bluetooth-adapter/
There are a bunch of these type of adapters, this one requires a USB 2.0 header on the motherboard but I believe there are some that don't.
Edit: it requires USB for bluetooth, so if you want both bluetooth and wifi that one would probably be the best option.
why no dark mode?
Current:
Watercooled Eluktronics THICC-17 (Clevo X170SM-G):
CPU: i9-10900k @ 4.9GHz all core
GPU: RTX 2080 Super (Max P 200W)
RAM: 32GB (4x8GB) @ 3200MTs
Storage: 1TB WD Blue NVMe SSD
Displays: Internal 1080p@300Hz, Asus ROG XG-17 1080p@240Hz (G-Sync), Gigabyte M32U 4k@144Hz (G-Sync), External Laptop panel (LTN173HT02) 1080p@120Hz
Asus ROG Flow Z13 (GZ301ZE):
CPU: i9-12900H @ Up to 5.0GHz all core
- dGPU: RTX 3050 Ti 4GB
- eGPU: Radeon 6850m XT XGm 16GB
RAM: 16GB (8x2GB) @ 5200MTs
Storage: 1TB NVMe SSD, 1TB MicroSD
Display: Internal 1200p@120Hz
Minisforum MS-A2:
CPU: Ryzen 9 9955HX
RAM: 63GB (2x32GB) DDR5 @ 5600MTs
Storage: 2x 1TB Various NVMe SSD in RAID 1, 4x 10TB HGST Enterprise HDD in RAID Z1
https://linustechtips.com/topic/1098157-wifi-bluetooth-adapter/#findComment-12841403
