Need Recommendation for Closed Loop Upgrade
Solved by WoodenMarker,
7 minutes ago, Erudito said:I'd still like a cooler solution. May seem normal but I want to keep this processor for a long time, so the cooler the better.
Your temps are fine and the cooler is much more likely to fail before the cpu. You're not going to get a significantly better 240mm AIO. Better fans may lower temps or noise.
Even if you can lower temps, the difference in cpu longevity is probably negligible -- like going from 20+ years to 25+ years. You might be better off getting better cooling for the motherboard if you're after longevity.
