Any advice for my ITX build.
PCPartPicker Part List
Type Item Price
CPU Intel Core i5-3550S 3 GHz Quad-Core OEM/Tray Processor
CPU Cooler Cooler Master i71C RGB 37 CFM Rifle Bearing CPU Cooler $19.99 @ B&H
Motherboard MSI H61I-E35 (B3) Mini ITX LGA1155 Motherboard
Memory G.Skill Value Series 8 GB (1 x 8 GB) DDR3-1333 Memory $32.99 @ Newegg
Storage ADATA Ultimate SU650 120 GB 2.5" Solid State Drive $21.99 @ Amazon
Case Aerocool CS-101 MicroATX Slim Case
Custom Royal Kludge RK61 RGB mechanical Keyboard $30.00
Custom AZZA SFX 250W $20.00
  Prices include shipping, taxes, rebates, and discounts
  Total $124.97
  Generated by PCPartPicker 2019-08-23 14:35 EDT-0400
@Fasauceome I want the case you showed be but I am too broke and will have to save up for another 2 months
If you want me to see your reply, please tag me @Faisal A
https://linustechtips.com/topic/1097215-mini-itx-build/
gotta have goals, something to work towards for your next big upgrade
do you plan on buying the ram new instead of used? Are you buying from the US?
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1097215-mini-itx-build/#findComment-12833861
48 minutes ago, Faisal A said:
@Fasauceome I am buying it used for £17. I am buying from the UK. I am thinking, is it better to spend the money on a good case or good hardware ?
Well, from the looks of your budget constraints, the hardware is all you can get. The motherboard doesn't even have a PCIe x16 slot so you must be paying pretty little for that (also note it'll inhibit graphics card additions)
Primary PC:
PSU tier list
https://linustechtips.com/topic/1097215-mini-itx-build/#findComment-12834033
