hi guys, sorry i'm sure there's like the exact thread posted somewhere but i don't really browse here much, hence why i didn't spend a bunch of time looking.
basically, i have no idea what power supply to replace my current one with. LTT seems to push Seasonic quite hard, but i know there are other good options.
i used Seasonic's wattage calculator and it recommended i need a 750w power supply. my current one is a no-named generic i had ibuypower put in my computer when i didn't know what i was doing, and after upgrading to the RX 580 it makes funky sounds when under load.
here are my questions:
- with modular PSU's, do they come with the cables i will need or do i have to order them separate?
- would a non-modular / semi-modular have everything i need assuming i'm not a stickler about cable management? (build below)
- is Seasonic the brand to beat, or are there others some of you might recommend?
thanks, i'm just nervous about change :)
build:
3770k
16gb DDR3 RAM
Radeon RX 580
soundcard / SATA SSD / SATA HDD / optical drive (what even are those anymore)
https://linustechtips.com/topic/1096183-replacement-psu/
unfortunately PSU calculators are rather unreliable
3 minutes ago, shadow_FIX said:
3770k
16gb DDR3 RAM
Radeon RX 580
this rig draws less than 400 watts. In my signature I put my power draw as a point of reference, and you can click my power supply for a link to the PSU tier list.
all cables will be included
yep, the only advantage modular PSUs have is the removable cables, nothing else.
It's not about brand, it's about quality. I also have some topics linked in my signature at the bottom about some Seasonic power supplies that have issues.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1096183-replacement-psu/#findComment-12825378
brilliant, thanks friend. seeing a crowdsourced tier list was exactly the kind of thing i was after for piece of mind.
make sure you quote people or use @fasauceome so we see your responses
Primary PC:
PSU tier list
https://linustechtips.com/topic/1096183-replacement-psu/#findComment-12825406
You can find which cables are included on the product website.
Depends on the case.
Seasonic has few interesting options. I wouldn't recommend any brand, I would recommend specific PSUs. Which PSUs, depends on where you're buying from and what you're powering.
https://linustechtips.com/topic/1096183-replacement-psu/#findComment-12825443
All the necessary cables, in all fully modular, semi-modular, and non-modular scenarios, are included.
These days, the cables are usually all black, or "mustard and ketchup" wrapped in a mesh outer jacket.
Of course, you can always order a set of custom cables, like the ones CableMods offer.
https://cablemod.com/product-category/full-cable-kits/
Cables are usually PSU brand / model specific, so determine WHICH PSU you want before buying the custom cables.
For your system, even a quality 500W ~ 550W will give you 100W+ of extra headroom.
650W ~ 750W would even accommodate for a second RX-580.
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/1096183-replacement-psu/#findComment-12825444
OMG why didn't I think of that! I always need to find the list at the worst moment...
Quote and/or tag people using @ otherwise they don't get notified of your response!
The HUMBLE Computer:
AMD Ryzen 7 3700X • Noctua NH-U12A • ASUS STRIX X570-F • Corsair Vengeance LPX 32GB (2x16GB) DDR4 3200MHz CL16 • GIGABYTE Nvidia GTX1080 G1 • FRACTAL DESIGN Define C w/ blue Meshify C front • Corsair RM750x (2018) • OS: Kingston KC2000 1TB GAMES: Intel 660p 1TB DATA: Seagate Desktop 2TB • Acer Predator X34P 34" 3440x1440p 120 Hz IPS curved Ultrawide • Corsair STRAFE RGB Cherry MX Brown • Logitech G502 HERO / Logitech MX Master 3
Notebook:  HP Spectre x360 13" late 2018
Core i7 8550U • 16GB DDR3 RAM • 512GB NVMe SSD • 13" 1920x1080p 120 Hz IPS touchscreen • dual Thunderbolt 3
https://linustechtips.com/topic/1096183-replacement-psu/#findComment-12825452
I have the 3 main tier lists I use most linked in my parts list, comes in handy.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1096183-replacement-psu/#findComment-12825455
this young padawan still has much to learn
https://linustechtips.com/topic/1096183-replacement-psu/#findComment-12825459
i think i will likely end up going with the Corsair RM650. Tier A on the PSU list, and while it's overkill for my current system, it carries a 10yr warranty and since my tower was built in 2012, there's a strong possibility this PSU could go into my next computer.
thanks for making an otherwise confusing decision in a crowded market much, much easier. :)
https://linustechtips.com/topic/1096183-replacement-psu/#findComment-12825584
