they usually have a few less PCIe lanes and can come with a few less features like sata ports, fan connectors, etc. but for the most part there is not much difference and personalty If you dont need allot of extras its actualy best to go with the Micro ATX or even mini ITX. It just makes your life easier when it comes time to move it.
https://linustechtips.com/topic/1096149-micro-atx-vs-full-atx/#findComment-12825145
Genrally speaking, MicroATX tends to haave a more Spartan fearure set vs. both Mini ITX and full ATX, and thus are less expensive than either of the others.
There are less models in this form factor available, and some of this is because it is the "in between" form factor that is almost as big as full ATX, and isn't small enough compared to Mini ITX.
I have a few MicroATX boards because they met my criteria for space vs features and price the best, but generally I recommend either going full ATX or Mini ITX.
i5-14600KF // 120x38MM Cooler Master AIO // B760i // 64GB DDR5 6000 // PNY RTX 5070 // Cooler Master NCORE 100 Max // Cooler Master V SFX-850 Gold // UWQHD AOC Display
https://linustechtips.com/topic/1096149-micro-atx-vs-full-atx/#findComment-12825547
Unless you're running SLI, mATX is likely to handle everything you throw at it. It's essentially an ATX motherboard with the bottom 3-4 expansion slots cut off.
CPURyzen 7 5800X with Arctic Liquid Freezer II 120mm AIO & push-pull Arctic P12 PWM fans RAM: G.Skill Ripjaws V 4x8GB 3600 16-16-16-30
PSU: Be Quiet! Pure Power 12 M 1000W GPUASRock RX 5700 XT Reference with Eiswolf GPX-Pro 240 AIO & 2x Arctic P12 PWM fans Case: Antec P5
MotherboardASRock X570M Pro4 Monitor: ASUS ROG Strix XG32VC Storage: HP EX950 1TB NVMe, Mushkin Pilot-E 1TB NVMe, 2x Constellation ES 2TB in RAID1
https://hwbot.org/submission/4497882_btgbullseye_gpupi_v3.3___32b_radeon_rx_5700_xt_13min_37sec_848ms
https://linustechtips.com/topic/1096149-micro-atx-vs-full-atx/#findComment-12825900
Ill say, every ATX mobo build I have had I always tend to think is too damn big.  And the two mini ITX builds have been great, but obviously they have their sacrifices (tight to work in, less air flow, etc).  I think microATX might be the winner in my opinion.  A small microATX build might be the best option.
El Zoido:  9900k + RTX 4090 / 32 gb 3600mHz RAM / z390 Aorus Master
The Box:  3900x + RTX 3080 /  32 gb 3000mHz RAM / B550 MSI mortar
https://linustechtips.com/topic/1096149-micro-atx-vs-full-atx/#findComment-12825966
