So my PC has been acting funny recently and I have no idea why. I've factory reset and clean installed and the problems (games crashing. "Aww snap" chrome error every once in a while) keep happening. I traced the issue to possibly my system32 being buggy, and I tried the sfc/scannow command but it gave me "Windows Resource Protection found corrupt files but was unable to fix some of them". I'll put the CBS.log in to give the most detail I can to fix the issue, but I'm lost after that. Any help is appreciated, and thanks in advance if I personally forget to do so!
CBS.log
https://linustechtips.com/topic/1095932-cbslog-fix-help/
that log file show many corrupted and mismatched. I suggest do a complete format reinstall and download the ISO from Microsoft website.
Any BSOD? I suspect your RAM got problem as well, try check with Memtest.
https://linustechtips.com/topic/1095932-cbslog-fix-help/#findComment-12823143
So you're saying clean installing from a Media Creation USB won't do the trick (as it's what I used to clean install Windows 10)?, I did get "Memory_Managment" BSOD a couple times yesterday and the day before that, so I'll take a look at my RAM.
https://linustechtips.com/topic/1095932-cbslog-fix-help/#findComment-12823256
Most probably RAM related and that causing your files to get corrupted, format again after you change it to new one if that was the problem.
https://linustechtips.com/topic/1095932-cbslog-fix-help/#findComment-12823262
I ran through Widows Memory Diagnostic tool and turns out it was the RAM indeed. But the RAM is brand new (give or take a few weeks), what could I have done to already ruin it enough to cause such problems? Can you damage RAM with software issues? Or did I just put it in wrong somehow? I've attached screenshot results to to this reply.
https://linustechtips.com/topic/1095932-cbslog-fix-help/#findComment-12823341
Try remove one stick and run memory test again.
I don't think software can cause it unless you overvoltage it.
https://linustechtips.com/topic/1095932-cbslog-fix-help/#findComment-12823520
