just dont get TT watercooling stuff. low quality leak prone and poor performance
Builds:
https://linustechtips.com/topic/1095685-replacement-parts/#findComment-12820911
10 minutes ago, Wisco_Mudder said:
Anyone know if Thermaltake sells replacement parts for the D5 res/pumps? I have one with a broke extension tube and wanted a new tube but I could McGyver it... I just want the lazy way about it...  Help me Obi Wan!
Ask customer support nicely, they might send you some they have for me previously.
Bethesda PC:   R7 3700X  -  Asrock B550 Extreme 4  -  Corsair Dominator Platinum RGB 16GB@3.6GHz -  Zotac AMP Extreme 1080TI -  Samsung 860 Evo 256GB  -  WD Blue 2TB SSD -  500DX  -  Stock cooling lul  -  Rm650x
CrumpleBox V3:  Xeon X5680  -  Asus X58 Sabertooth  -  DDr3 16GB@1.33Ghz  -  Gigabyte 1660s -  TT smart RGB 700W  -
Cooler Master Storm Trooper  -  120GB Samsung 850 Pro   -  LTT Edition Chromax NH-D15 ?
CrumpleBox 3 ROTF: I5-6400  -  MSI B150m Mortar  -  16GB 2133Mhz Vengeance Pro RGB  -  Strix 1070Ti - GTX 1070 FE  -  Adata 128GB SSD  -  Fractal Design Define C  -  Gammaxx 400V2  -  Cooler Master silent pro gold 1000W
CrumpleBox 2: i7-7820x - MSI X299 Raider - 32GB Thermaltake Toughram 3.6Ghz - 2x Sapphire Nitro Fury - 128GB PCie Adata SSD - O11 Dynamic - EVGA CLC 360 - Corsair RM1000X
Perhiperals:  Gateway 900p60 monitor  -  Dell 1024x768@75  -  Logi. G403 Carbon  -  Logi. G502  -  SteSer. Arctis 5  -  SteSer. Rival 110 - Corsair Strafe RGB MK.2
https://linustechtips.com/topic/1095685-replacement-parts/#findComment-12820933
7 minutes ago, Wisco_Mudder said:
That doesn't really solve the current issue, but thanks you for the advice for future reference.
I would get a new D5 pump body from somewhere nice
Builds:
https://linustechtips.com/topic/1095685-replacement-parts/#findComment-12822130
is there a particular site you would recamend... its the PR22-d5 res/pump... I saw "resivours" with the tube in the bottom  but can't tell if i could just use it for parts. Otherwise I'm thinking of finding some tubing and using "instamorph" and making something work.
https://linustechtips.com/topic/1095685-replacement-parts/#findComment-12822156
