6 minutes ago, knapalmium said:
I heard good things about this board, I don't intend to overclock anything. And there's a lot of people that pair it with the gtx 1060.
I'm really on a tight budget. Bottom line is, will it still perform well?
yes. motherboard almost never reduces performance unless its something older than 3 or 4 years. something with pcie 2. and even then its very little. the cpu however might be a problem. if your cpu is too weak then it would be a waste of money on the rtx 2060. but you shouldnt worry too much. even a ryzen 5 1600 would be a very small bottleneck. so you'll be fine. but i do recommend you go at least b350 and if possible b450. they're much better and can use ryzen 3000 chips and are just better in every way.
It is said that an Italian dies every time Spaghetti is broken.
That's why I break mine twice.
https://linustechtips.com/topic/1094964-need-help-please-xd/#findComment-12815385
All will work together just fine.  A320 chipset boards are cheaper made, less options - but functionally they are same/same no difference when it comes to powering up a compatible CPU and GPU.
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
https://linustechtips.com/topic/1094964-need-help-please-xd/#findComment-12815398
Thank you very much for the reply. I'll list all of my parts bellow:
Gpu: Zotac Gaming GeForce RTX 2060 6GB
Processor: AMD Ryzen 5 2600 Hexa-Core 3.4GHz w/ Turbo 3.9GHz 19MB SktAM4
Motherboard: Micro-ATX ASRock A320M PRO4
Psu: Corsair VS650 80 Plus
3.5" Seagate Barracuda 1TB 7200RPM 64MB SATA III
SSD 2.5" SanDisk Plus 120GB MLC SATA
RAM G.SKILL Aegis 16GB (2x8GB) DDR4-3000MHz CL16
https://linustechtips.com/topic/1094964-need-help-please-xd/#findComment-12815401
id definitely go for a b450 motherboard because it has more pcie lanes, allows overclocking, has more features, more ports for USB, and it's already made for 2nd gen, meaning you won't need to use a first gen ryzen for updating bios. it will be just plug and play. b450 also is capable of running ryzen 3000 chips while a320 is not.
but its your choice. answer to your question: there won't be any problem. there won't be a bottleneck and everything will work with each other nicely as long as you dont try to overclock.
https://linustechtips.com/topic/1094964-need-help-please-xd/#findComment-12815416
