So. A couple days ago my PC crashed. And I got a dram error code 8. I restarted. Got into windows and 30 seconds in it crashed again with the same code.  I restarted several times. Checked my ram sticks in all the dims. I got new ram still had the same issue. Decided to get a new motherboard and the issue still hasn't been resolved. Any ideas on what's going on? Help would be appreciated.
Ryzen 1700 3.8 GHz
Deep cool captain 240
Asus croshair 6 hero
Gskill trident z 3000 16gb
Adata 512gb m.2
2tb Intel ssd6
We blue 1tb
Sapphire Vega 64
https://linustechtips.com/topic/1094062-problem-somewheremb-cpu/
Ryzen 1700 3.8 GHz
Adata 512gb m.2
2tb Intel ssd6
We blue 1tb
Sapphire Vega 64
Did you try fresh install of windows?
Internet Connection
My Rig: AMD Ryzen 9 3900X @ 4.3Ghz | Asus Prime X470-Pro | Corsair Vengeance RGB Pro 32 GB (4 x 8GB) DDR-4 3000Mhz OC'd @ 3400Mhz 16-20-20-38 |
EVGA RTX 2070 8GB XC Gaming OC @ 2145Mhz Boosted/ 1925Mhz Memory | WD SN750 500GB M.2 NVME | Gigabye 240GB SSD |
XSPC EX 360mm | Corsair XC7 RGB CPU WB | EK-Vector RTX 2080 | Alphacool Eisbecher D5 150mm Plexi | XSPC Fittings | XSPC FLX Clear 7/16" ID, 5/8" OD |
Corsair LL120 x6 | Corsair RM750x White 2018 | Corsair Commander Pro | Corsair Obsidian 500D RGB SE | Corsair RGB LED Lighting PRO Expansion |
Corsair Strafe RGB MK.2 | Corsair Ironclaw RGB Wireless 18,000DPI | Acer 32" 4K 60Hz HDR600 Cert. ET322QK CBMIIPZX |
Passmark Score
3dmark Score
PC Parts Picker Link to Build
Network
Netgear LBR20 LTE Router | Verizon Unlimited Prepaid Hotspot Plan
HP 2530-48G-PoEP Switch
Rasberry Pi 4 Running Pihole
Linksys Velop 3 Mesh Wifi AP's
