Problem with AIO and cpu
Go to solution Solved by Skiiwee29,
sitting in the upper 50s at idle is bad... Try tweaking the speed of your pump. Fan configuration matters very little truthfully if its in push or pull, Generally pull is the easiest of them for cleaning purposes, but push looks better because you dont have the messy structure support beams showing. I had a friend who has the H100i and her problem was the RPM of the pump was not enough and was causing her hi idle and load temps. Once I got her to tweak the pump speed, it is now working correctly.
So i got this AIO yesterday and it looks like this, also the fans are placed as intake since i have two exhaust fans in the back in my h500i case, is my radiator placement fine? Or did i place it wrong? Also will this help me do a comfortable OC on my ryzen 7 2700x? it's been running a bit too hot lately (took out the block for repaste don't mind it)
https://linustechtips.com/topic/1094020-problem-with-aio-and-cpu/
The Pump should not be the highest point in the system atleast turn the radiator upside down so air does not get trapped in the pump
The H500i is a terrible case for thermals. I had one and I loathed it. It has very little in terms of intake and with a 240mm rad mounted upfront it's even worse. I sold that case as quick as possible and bought a high airflow case that I could top mount the radiator in.
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
19 minutes ago, 5x5 said:
Is the pump working properly/have you updated the bios? That aio should be keeping a 2700X cool as a cucumber.
Yes done all that and still had some problem and hitting 85-88c on idle temps before I did the repaste it’s now at 60c idle and 76c at full load I am wondering why the original AIO paste was so bad?
21 minutes ago, Sorenson said:
That’s how you mount it in that case. You could flip it 180 if you have too much slack in the hoses.
So it should be ok AIO wise right? I gotta be honest this case was hard to work with in putting the AIO but at least my temps are better after the repaste so I guess problem solved
Tell me about it, all I’ve heard from tech reviewers were good things about this case but after actually owning it I’m seeing why some people are hating it and unfortunately I’ll have to stick with it, the AIO installation was horrible btw
Community Standards
"Beast Mode"
Dedicated Streaming Rig
It’s just an aesthetic thing, so if you like the way it looks don’t bother. I saw you mention in another comment about the stock paste being terrible. You’re not alone, I’ve used 3 Corsair AIO and always replace the included paste because it’s garbage.
Yeah the paste is a bit off lol but I am idling at 60c so I’m gonna take @Skiiwee29 suggestion and see if it helps
You're still doing something wrong - an AIO of that size should be in the 50s under load at stock.
Just figured it out It was set to no fan noise mode which turns them off I think? Explains why they were spinning only 5% of the time I can finally say it’s solved now idling at 48c
