Hello!
I am planning to build my little cousin a computer. He is mainly going to be using the internet and internet-based games (e.g Cool math games, Nitro type) I do not know what specs to do. He won’t be playing video games just the online games. I also need it fast enough for his parents to purchase products and surf the web. Appreciate all the responses.
https://linustechtips.com/topic/1093849-help-with-pc-specs/
4 minutes ago, emosun said:
buy a prebuilt for this as it'll save a lot of money.  a used workstation goes for under 300 something with 8-16gb of ram and a previous gen upper end xeon will do fine theres a million of them on ebay
I don’t want it to be a used product. It will be a gift for his birthday. I also want something that i built for him.
https://linustechtips.com/topic/1093849-help-with-pc-specs/#findComment-12806195
just keep in mind that a low cost new machine will be slower and use far cheaper parts than a previous gen high end machine. also keep in mind that your listed requirements are so light that most any computer from the past 9-10 years will be able to do the tasks you mentioned.
start off with a budget so people can assemble something around that , although again i wouldn't be spending to much on this build
https://linustechtips.com/topic/1093849-help-with-pc-specs/#findComment-12806197
You should read the sticky labeled "read before posting" for the section you posted this in. You're missing pretty much every piece of key info we'd need.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/1093849-help-with-pc-specs/#findComment-12806238
1 hour ago, Vainix said:
Hello!
PCPartPicker Part List
CPU: AMD Ryzen 3 2200G 3.5 GHz Quad-Core Processor  ($79.89 @ OutletPC)
Motherboard: MSI B450M PRO-M2 Micro ATX AM4 Motherboard  ($74.89 @ OutletPC)
Memory: Team Vulcan 8 GB (2 x 4 GB) DDR4-3000 Memory  ($41.89 @ OutletPC)
Storage: Patriot Burst 480 GB 2.5" Solid State Drive  ($47.99 @ Newegg)
Case: Thermaltake Versa H15 MicroATX Mid Tower Case  ($29.99 @ Newegg)
Power Supply: Thermaltake Smart 500 W 80+ Certified ATX Power Supply  ($35.99 @ Newegg)
Operating System: Microsoft Windows 10 Home OEM 64-bit  ($99.99 @ Best Buy)
Monitor: Acer K202HQL 19.5" 1600x900 60 Hz Monitor  ($64.99 @ Amazon)
Keyboard: Rosewill NEON K51W Wired Gaming Keyboard  ($29.99 @ Newegg Business)
Mouse: Kensington K72358US Wired Optical Mouse  ($7.54 @ Amazon)
Speakers: Cyber Acoustics CA-3090 10 W 2.1 Channel Speakers  ($20.95 @ Amazon)
Total: $534.10
Generated by PCPartPicker 2019-08-14 02:52 EDT-0400
https://linustechtips.com/topic/1093849-help-with-pc-specs/#findComment-12806264
