Help fixing laptop
Solved by The Torrent,
14 minutes ago, jg3 said:I am trying to learn how to fix old electronics I have as I find it interesting.
I have an hp pavilion 17-e020us laptop (Specs) that won't turn on. When I plug in the charger the charging light shows but pressing the power button doesn't work and no fans/display or any other lights come on. So far I have tried replacing the battery, using a different charger, hard resetting, and opening it up to see if everything looks normal. What should I do now to figure out what the problem is and fix it?
had that exact laptop and same problem, tried to fix it mobo problem think it was prob a broken relay or something - just scrap it its not worth much.
