Ryzen 5 3600 Temp spikes on idle
Pleo
Guys,
I've recently completed my ryzen 5 3600 + msi b450 tomahawk build.
Whilst gaming, the temps are a steady 60-68 degrees. However, in idle, it jumps from 35-47 in 1 second randomly. This can't be okay right? Anyone have an explanation/fix for this? I'm using ryzen master as a monitoring software. Also used CPU-Z, HWMonitor etc. All saying the same. Its just jumping from 35-50 and going back, then 50 again etc. This is with 2-5% cpu usage.
Thanks
Edit: My cores are always on 4GHz aswell. The cores keep jumping in idle.
I’ve had this with my 2700x too when I had no OC applied. Really odd
MSI B450 Pro Gaming Pro Carbon AC | AMD Ryzen 2700x  | NZXT  Kraken X52  MSI GeForce RTX2070 Armour | Corsair Vengeance LPX 32GB (4*8) 3200MhZ | Samsung 970 evo M.2nvme 500GB Boot  / Samsung 860 evo 500GB SSD | Corsair RM550X (2018) | Fractal Design Meshify C white | Logitech G pro WirelessGigabyte Aurus AD27QD
You saying OC'ing should fix this?
Could this have anything to do with thermal paste, or is this software or bios related?
Because on idle its 32 minimum, it just keeps jumping. voltage @ 1.4, etc.
As long as you aren't having any problems because of it and your load temps are normal then I'd say it's nothing to worry about.
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z690 Aorus Elite AX DDR4 | GPU - ASUS TUF Gaming OC RTX 4090 RAM - Corsair Vengeance Pro RGB 64GB 3600mhz | AIO - H150i Pro XT | PSU - Corsair RM1000X | Case - Phanteks P500A Digital - White | Storage - Samsung 970 Pro M.2 NVME SSD 512GB / Sabrent Rocket 1TB Nvme / Samsung 860 Evo Pro 500GB / Samsung 970 EVO Plus 2tb Nvme / Samsung 870 QVO 4TB  |
TV Streaming PC: Intel Nuc CPU - i7 8th Gen | RAM - 16GB DDR4 2666mhz | Storage - 256GB WD Black M.2 NVME SSD |
Phone: Samsung Galaxy Z Fold 4 - Phantom Black 512GB |
Not saying it’s fixing anything.
i think it might have to do with the PBO of ryzen. I just noticed once I manually OC’d it it didn’t happen anymore.
This is normal with Ryzen 3000 series due to Precision Boost Overdrive. My 3700x goes from 35 up to like 55-60c at idle due to PBO.
"Black Out"
1tb Samsung 970 Evo | 2x 2tb Crucial MX500 SSD | Fractal Design Meshify S2 | Corsair HX1200 PSU
Dedicated Streaming Rig
 Ryzen 7 3700x | Asus B450-F Strix | 16gb Gskill Flare X 3200mhz | Corsair RM550x PSU | Asus Strix GTX1070 | 250gb 860 Evo m.2
  • 4 months later...
Had the same problem. Turning on high performance in power options seemed to help slighting with fans ramping up due to heat spikes, they are now relatively quick spikes, ill probably play around with overclocking to see if it helps as ppl r saying its to do with PBO, but so far using the high performance power plan seemed to help.
Even with PBO off (I've set it to off since day 1) it happens.  It's just how it is.  It's just random processes pinging the CPU and the CPU responding to it by boosting clock speeds.  You'll see the temps never last more than a few seconds.
QUOTE ME IN A REPLY SO I CAN SEE THE NOTIFICATION!
When there is no danger of failure there is no pleasure in success.
  • 3 weeks later...
I have a 3600X and get these as well and cant figure it out.
Also got a 3600x i had high temps even with my Cooler Master Hyper 212 Turbo LED it will idle around 50up the solution i found was to under volt and under clock used the bios and did it manually
i went to bios and put my Core clock to 4.2ghz and the Cpu voltage to 1.3125 after that i kinda got improved performance on the cpu and better idl temps
now it idls at 36 degrees to 40 it's much better than before.it seems like the sweets spot for the 3600x
i tried multiple settings here and there and thous cpu settings are the best i got so far on the 3600x
  • 2 months later...
Hi can u show bios settings? cuz when i change cpu voltages to manual they going to be static always on same value i make.
  • 2 weeks later...
so i had the same problem that made me go crazy
the solution for me was in the bios i enabled amd cool nd quiet hope this help someone
I had the same issue with my 1600x without an OC but when i applied an OC it went away...Now with my 3600 im having the opposite issue. With an OC applied i get weird temp spikes and when i leave it alone no spikes. I assume its something to do with my motherboard the way it is sending power to the chip. I only really applied the OC before to get rid of the temp spikes so now its just 1 less step i guess.
