Okay so I did some digging in the bios and looks like my motherboard isn't allowing me to use PCIE 3.0 even tho I now currently use a 1060 6GB which supports 3.0, my mother board also supports 3.0 but its not visible in the bios.
Mother Board and drivers are up to date.
CPU: Intel i7-4770K 4.4Ghz could use help with some fine tuning to squeeze out any more performance. Not an expert on overclocking lol.
OS: WIndows 10 Home 64-bit
SSD: Samsung SSD 850 EVO 250GB
HDD: Several Western Digital Hard Drives
GPU: ASUS GeForce GTX 1060 6GB Dual-Fan OC Edition
Monitor: AOC 2236Vw Widescreen 21.5-inch LCD.
Side Monitor: some pos dell lol
Mobo: ASUS Z97-A/USB 3.1
Ram: Patriot 16GB(2x8GB) Viper III DDR3 1866MHz (PC3 15000) CL10
Psu: Corsair Gaming Series 800-Watt
https://linustechtips.com/topic/1093714-update-still-need-help/
Some boards "downclock" to 2.0 when the GPU card is idle.
Have you installed WIn10 already? There are programs that can show you what sped the PCIe is under load.
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
https://linustechtips.com/topic/1093714-update-still-need-help/#findComment-12805177
I am on windows 10 and Im aware of that but even in bios there is no option for 3.0 my bios is using 2.0 only and below
https://linustechtips.com/topic/1093714-update-still-need-help/#findComment-12805290
Download and run GPU-Z, about midway down the right-hand side of the 1st tab (Graphics Card) will be a question mark right next to "Bus Interface" click on that and follow the instructions.
Mine, for example, sitting at idle, says "PCIe x16 3.0 @x16 1.1" and doesn't get up to 3.0 unless the video card is stressed.
(EDIT: typos)
https://linustechtips.com/topic/1093714-update-still-need-help/#findComment-12805396
As long as everything performs as it should, I can't say I'd worry about it too much.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/1093714-update-still-need-help/#findComment-12805409
Just now, Chronicle Drew said:
Im getting some studder and frame drops in certain games so I dont think its performing at full capacity
That could also entirely be down to your CPU (no matter how you flip it, 4C/8T is starting to not be enough) and storage depending on what game it is. Hell it could be drivers given how "amazing" Nvidia's drivers have been. Blaming it on something like this just because it seems like the culprit is kinda jumping the gun a bit.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/1093714-update-still-need-help/#findComment-12805441
you probably wouldnt get stutter or frame drops, but just generally lower frames
Specs v-v
Cpu: Ryzen 9 3900x @ 1.1v / Motherboard: Asus Prime X570-P / Ram: 32GB 3000Mhz 16-16-16-36 Team Vulcan (4x8GB) / Storage: 1x 1TB Lite-on EP2, 2x 128GB PM851 SSD, 3x 1TB WD Blues / Gpu: GTX Titan X (Pascal) / Case: Corsair 400c Carbide / Psu: Corsair RMi 750w / OS: Windows 10
I'm lonely, PM me to be my friend!
https://linustechtips.com/topic/1093714-update-still-need-help/#findComment-12805464
