Help picking graphics card cooling
Go to solution Solved by Zando_,
For the 5700XT, an AIB card like the ones @Mnky313 mentioned. The blower cooler will suffice if you wanna slap the fans up to a much higher RPM than stock, but you'll still have slightly higher temps and a heck ton more noise. The 5700 apparently doesn't suffer too much even with the blower, but the XT defo needs the better cooling performance. Only reason to get the XT as a blower would be if you're in a very cramped chassis and need the heat exhausted straight out the back, or plan to put a waterblock on it.
Get the open air cooler. Don't buy the blower cooler. You can pay like $20 or $30 more and you will get a much better graphics card.
Join HWBot or OCN
#1 3DM Fire Strike Ultra score in the world.
#2 3DM Time Spy Extreme score in the world.
#3 3DM Fire Strike Extreme score in the world.
#7 3DM Sky Diver score in the world.
#8 3DM Fire Strike score in the world.
#12 3DM Time Spy score in the world.
All scores obtained with 8600K + 1x 1070Ti. Links in bio
Open Air, get a card like the Sapphire Pulse or ROG Strix. They will cool a lot better than the blower style.
why no dark mode?
Current:
Watercooled Eluktronics THICC-17 (Clevo X170SM-G):
CPU: i9-10900k @ 4.9GHz all core
GPU: RTX 2080 Super (Max P 200W)
RAM: 32GB (4x8GB) @ 3200MTs
Storage: 1TB WD Blue NVMe SSD
Displays: Internal 1080p@300Hz, Asus ROG XG-17 1080p@240Hz (G-Sync), Gigabyte M32U 4k@144Hz (G-Sync), External Laptop panel (LTN173HT02) 1080p@120Hz
Asus ROG Flow Z13 (GZ301ZE):
CPU: i9-12900H @ Up to 5.0GHz all core
- dGPU: RTX 3050 Ti 4GB
- eGPU: Radeon 6850m XT XGm 16GB
RAM: 16GB (8x2GB) @ 5200MTs
Storage: 1TB NVMe SSD, 1TB MicroSD
Display: Internal 1200p@120Hz
Minisforum MS-A2:
CPU: Ryzen 9 9955HX
RAM: 63GB (2x32GB) DDR5 @ 5600MTs
Storage: 2x 1TB Various NVMe SSD in RAID 1, 4x 10TB HGST Enterprise HDD in RAID Z1
3 minutes ago, grant108 said:
I'm gonna buy a rx 5700 xt for sure, should I get a blower type cooler or a open air cooler. My case is the nzxt h500i.
I would leave it alone since its rather new and custom cooling is sorta statrting to pop up and what not.
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
