I need to find a monitor
Cole Evard
So I'm a console gamer but I want to start on PC but I can't afford one. So I want to find a monitor on a crazy low budget that has an hdmi port
Crazy low as in Ebay or Craiglist or Facebook marketplace used monitor?
What country/region and budget?
Onyx AMD Ryzen 7 7800x3d / MSI 6900xt Gaming X Trio / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 32GB / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 850 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502
7800X3D - PBO -30 all cores, 4.90GHz all core, 5.05GHz single core, 18286 C23 multi, 1779 C23 single
Emma : i9 9900K @5.1Ghz - Gigabyte AORUS 1080Ti - Gigabyte AORUS Z370 Gaming 5 - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - EVGA SuperNova 650 P2 - Thermaltake Water 3.0 Ultimate 360mm - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Raven: AMD Ryzen 5 5600x3d - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200Mhz - XFX Radeon RX6650XT - Samsung 980 1TB + Crucial MX500 1TB - TP-Link AC600 USB Wifi - Gigabyte GP-P450B PSU -  Cooler Master MasterBox Q300L -  Samsung 27" 1080p
Plex : AMD Ryzen 5 5600 - Gigabyte B550M AORUS Elite AX - G. Skill Ripjaws V 16GB 2400Mhz - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + WD Red NAS 4TBx2 - TP-Link AC1200 PCIe Wifi - EVGA SuperNova 650 P2 - ASUS Prime AP201 - Spectre 24" 1080p
Steam Deck 512GB OLED
OnePlus:
Other Tech:
- Ubiquiti Amplifi HD mesh wifi
You gotta be more specific. What performance are you tarketing? 1080p 60hz? 1080p 144hz? You could find a trash 720p monitor for cheap if you wanted but it wouldn't fit anyone's needs
Why don't you use your console's TV? I haven't used a monitor in a long, long time.
Go for a CRT if you are ok with VGA.
Desktop:
AMD Athlon 64 x2 4600+ (@ 3.00ghz)
ATI Radeon X1950XTX
MSI K9A2 Platinum (ms-7376)
Generic/Unknown PSU (350w)
AMD Phenom Stock CPU Cooler
Philips 107T5 (Will be replaced soon)
1GB Elpida OEM DDR2 (Will be replaced soon)
(our head priest's name is ZUN in all caps)
