18 minutes ago, MonkeyDelta said:
i need a new gaming rig and i'm on a budget of $800-900.
Was wondering if these parts will be good for a gaming rig, to pull any game on medium/high setting?
feel free to come with any improvements or change anything that is unnecessary.
Nah, build this instead (see below for more):
AMD is a better choice over Intel at this price point. Anyway, a 240mm AIO is overkill for a 6c 6t CPU with a TDP of 65W.  With a budget of 600 or more, it's pretty inexcusable to not get 16 GB or more RAM (it is 2019, after all).
The SSD I picked also has 512MB cache.
The H500 is an OK case, but I would upgrade to a Meshify C for better airflow. There are many posts online and on this forum about the G3, go have a look.
If you want to bring the price down a bit, you could get a CX550M and a 240GB SSD instead.
This machine will give you a lot more performance than your old list.
(Sorry if I was a bit negative in this post)
https://linustechtips.com/topic/1093632-first-time-building/#findComment-12804625
Thanks for the suggestion and no problem about the negativity, I take it as constructive criticism :D
I will write it down and definitely think about it.
the parts I choose i about $80 less.
https://linustechtips.com/topic/1093632-first-time-building/#findComment-12804822
PCPartPicker Part List
CPU: AMD Ryzen 5 2600X 3.6 GHz 6-Core Processor  ($145.89 @ OutletPC)
Motherboard: ASRock B450M Steel Legend Micro ATX AM4 Motherboard  ($89.98 @ OutletPC)
Memory: G.Skill Trident Z RGB 16 GB (2 x 8 GB) DDR4-3200 Memory  ($104.89 @ OutletPC)
Storage: Patriot Burst 480 GB 2.5" Solid State Drive  ($47.99 @ Newegg)
Video Card: MSI GeForce GTX 1660 Ti 6 GB GAMING X Video Card  ($274.99 @ Newegg)
Case: Corsair Carbide Series 275R ATX Mid Tower Case  ($69.99 @ Newegg)
Power Supply: Thermaltake Toughpower GOLD 750 W 80+ Gold Certified Semi-modular ATX Power Supply  ($65.99 @ Walmart)
Operating System: Microsoft Windows 10 Home OEM 64-bit  ($99.99 @ Best Buy)
Total: $899.71
Generated by PCPartPicker 2019-08-13 16:04 EDT-0400
https://linustechtips.com/topic/1093632-first-time-building/#findComment-12805084
