Hey there fellow people, I have finally decided that I want my next build to be a custom water cooled build. I think I am pretty dead set on the case which is going to be a Lian Li 011 dynamic. I just need some inspiration from you fellow builders so I can have some idea of what I want to do. Probably important information but I want to go all rigid tubing if possible.
https://linustechtips.com/topic/1092765-future-water-cooling-build/
2 minutes ago, Ravendarat said:
I havent built in that one but I do know there is a distribution plate for that thing, I think they look better than standard tanks but thats just my personal opinion
Could you possibly link me to this? I think aesthetically it would look better and probably would allow me to use more room for possibly a thicker rad on the vertical side if needed
@codenave If you go to ebay and type in Lian Li PC-001 Dynamic Waterway, there's a few to choose from.
This is one that I found, no promises that it's the best one. Just the first one that came up.
CPU: i7-8700k MOBO: MSI MAG Tomahawk Z390 RAM: Corsair Vengeance RGB PRO 32GB 3200MHz GPU: 1080ti
