Hey guys. I’ve had Rx570 Msi GamingX 4gb for a few months because I had a lower budget. I caught it on eBay for around 80 dollars. The previous owner used it for mining in a 4card system. He said the cards were undervolted and underclocked. Anyways. I run games at highest setting I can for above 60 FPS but temps get to around 77-83C. I replaced the thermal paste and cleaned the heat spreaders fins. The cpu runs at about the same. Considering I have a midsize case, 1 intake 120 mm fan, 1exhaust, 90 mm exhaust so that gives an idea on air flow. It’s a fbm01 case. I know it’s not a good looking case but I don’t want it to have a “expensive” look to it if you know what I mean, plus I still use the 5.25 inch bays. I run the cards fans capped at 70% because the fans are loud af but still top temps at 77-83. I have cleaned the cables up as good as the case would allow. I have a picture of the system attached. Is the temperatures safe? Also the block at the bottom right of the card is there for support to keep it from sagging.image.thumb.jpg.b99a95beaaa7b9e091c8a11a5fbedede.jpg
https://linustechtips.com/topic/1092714-rx-570-temps/
2 hours ago, Oalei said:
are you talking about the case or the temps? maybe something else.
I think he was talking about gpu temps. But also on the subject of the case, its also not that great for airflow, which im sure youre aware of lol.
Gaming Rig:
CPU: Ryzen 7 3700x  Cooler: Wraith Prism    RAM: 32gb G.Skill Tridentz RGB 3200mhz     Mobo: Asrock X570 Taichi
Graphics Card: Powercolor Red Devil RX 5700 XT     Case: Fractal Design Meshify C Dark TG     PSU: Corsair RM850x
Storage: 250gb Samsung 960 EVO, 2TB Seagate Barracuda
HTPC/VR Rig:
CPU: Ryzen 5 1600     Cooler: Noctua NH-L9a     RAM: 16gb Crucial Ballistix Sport 3200mhz     Mobo: Gigabyte B450 Aorus Pro Wifi ITX
Graphics Card: Powercolor Red Devil RX 580 8gb     Case: Fractal Design Node 202     PSU: Corsair SF600
Storage: 120gb Kingston A400, 500gb Samsung 860 EVO
Streaming Rig:
CPU: Ryzen 5 1600 @ 4ghz OC     Cooler: Cooler Master Hyper 212 Black Edition    RAM: 8gb Corsair Vengence LPX 2400mhz     Mobo: ASRock B450 Pro4 MATX
Graphics Card: Powercolor Red Dragon RX 570 4gb     Case: Inwin 301 White/Blue     PSU: Evga 450BR
Storage: 240gb Crucial BX500, 1TB Seagate Barracuda
https://linustechtips.com/topic/1092714-rx-570-temps/#findComment-12797692
