PSU for first build!!
Solved by OrionFOTL,
On the outside, CX450M has two PCIE connectors and is semi-modular, so you can detach some unused cables. CX450 has just one connector and isn't modular.
On the inside, CX450M uses a little worse technology which can cause whining if it's paired with top graphics cards like 1080 or 2080. CX450 uses better technology which doesn't cause any whining with anything.
