Hi.
I just got my new EVGA RTX 2080TI XC Ultra the problem is at 1080p im gettin avg. 90 fps Highs settings in GTA5, avg.90 fps Ultra 1080p Insurgency:Sandstorm.
Weird thing is even at 4k Im getting the same fps in GTA5, it stays avg.90fps.
Im running i7 5820k 4.1Ghz oced and 16GB 2133Mhz ram.
Non of my CPU cores went beyond 70% usage.
Cpu Temp:50-70C
Gpu Temp:50C
https://linustechtips.com/topic/1091999-rtx-2080ti-low-fps/
3 minutes ago, guywithprob said:
Hi.
Cpu Temp:50-70C
Gpu Temp:50C
Did you ddu the old drivers?
|King Of The Lost|
Project Dark: i7 7820x 5.1GHz | X299 Dark | Trident Z 32GB 3200MHz | GTX 1080Ti Hybrid | Corsair 760t | 1TB Samsung 860 Pro | EVGA Supernova G2 850w | H110i GTX
Lava: i9 12900k 5.1GHz (Undervolted to 1.26v)| MSI z690 Pro DDR4| Dominator Platnium 32GB 3800MHz| Power Color Red Devil RX 6950 XT| Seasonic Focus Platnium 850w| NZXT Kraken Z53
Unholy Rampage: i7 5930k 4.7GHz 4.4 Ring| X99
Rampage|Ripjaws IV 16GB 2800 CL13| GTX 1080 Strix(Custom XOC Signed BIOS) | Seasonic Focus Platinum 850w |H100i v2
Revenge of 775: Pentium 641 | Biostar TPower i45| Crucial Tracer 1066 DDR2 | GTX 580 Classified Ultra | EVGA 650 BQ | Noctua NH D14
https://linustechtips.com/topic/1091999-rtx-2080ti-low-fps/#findComment-12792207
From what I've read up, the 5820k with an overclock of anything less that 4.3ghz will run like that with the 2080ti, is it possible for you to overclock it to 4.3ghz or higher? If not I'd say it's probably time for a CPU upgrade.
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
https://linustechtips.com/topic/1091999-rtx-2080ti-low-fps/#findComment-12792237
I tried to go with 4.3 but when running stress test CPU temp goes beyond 80C so I turned it down.
https://linustechtips.com/topic/1091999-rtx-2080ti-low-fps/#findComment-12792243
What CPU cooler do you have?
https://linustechtips.com/topic/1091999-rtx-2080ti-low-fps/#findComment-12792244
1 minute ago, guywithprob said:
Noctua nh-d15.
Dang that's a pretty beefy cooler, if that can't keep it cool then that 5820k gets wicked hot.
https://linustechtips.com/topic/1091999-rtx-2080ti-low-fps/#findComment-12792248
It might be my fault too Im not that experienced oc'ing CPU. I turned the Core Voltage up to 1.2 maybe i should go with lower voltage but I don't really know.
https://linustechtips.com/topic/1091999-rtx-2080ti-low-fps/#findComment-12792256
Iirc tjmax on those is like 105c
In a stress test anything under that is probably fine
i5-14600KF // 120x38MM Cooler Master AIO // B760i // 64GB DDR5 6000 // PNY RTX 5070 // Cooler Master NCORE 100 Max // Cooler Master V SFX-850 Gold // UWQHD AOC Display
https://linustechtips.com/topic/1091999-rtx-2080ti-low-fps/#findComment-12792326
