Hi so i bought a gt 1030 graphics card a while ago(i had gt 210), I had core 2 duo E7500 but then i wanted to upgrade the cpu so I bought a used core 2 quad q9550 and then I noticed that the temperature is about 80c (the maximum temp for core 2 quad on intel website is 71c )  after that I started to see massive frame drops in games (like cs go on 720p low everything runs at around 100 fps then it suddenly became 5 fps and other games too)  so I really want to know what is causing this problem.
Thanks
p.s: my pc specs are
4gb ram
gt 1030
core 2 quad q 9550
msi g41m-p26 mb
and 500watt power supply(not really 500 watts its cheap power supply runs about 350 watts i guess)
monitor 1080p
https://linustechtips.com/topic/1091837-frame-drop-in-games-help/
Thanks
4gb ram
gt 1030
core 2 quad q 9550
msi g41m-p26 mb
monitor 1080p
It might be RAM, try monitoring RAM usage in game, 4GB is not a lot especially with windows 10.
why no dark mode?
Current:
Watercooled Eluktronics THICC-17 (Clevo X170SM-G):
CPU: i9-10900k @ 4.9GHz all core
GPU: RTX 2080 Super (Max P 200W)
RAM: 32GB (4x8GB) @ 3200MTs
Storage: 1TB WD Blue NVMe SSD
Displays: Internal 1080p@300Hz, Asus ROG XG-17 1080p@240Hz (G-Sync), Gigabyte M32U 4k@144Hz (G-Sync), External Laptop panel (LTN173HT02) 1080p@120Hz
Asus ROG Flow Z13 (GZ301ZE):
CPU: i9-12900H @ Up to 5.0GHz all core
- dGPU: RTX 3050 Ti 4GB
- eGPU: Radeon 6850m XT XGm 16GB
RAM: 16GB (8x2GB) @ 5200MTs
Storage: 1TB NVMe SSD, 1TB MicroSD
Display: Internal 1200p@120Hz
Minisforum MS-A2:
CPU: Ryzen 9 9955HX
RAM: 63GB (2x32GB) DDR5 @ 5600MTs
Storage: 2x 1TB Various NVMe SSD in RAID 1, 4x 10TB HGST Enterprise HDD in RAID Z1
  • 2 weeks later...
