Hey guys, this topic may feel a bit vague as I've not actually been to my friends to have a look yet but here's the story.
Few days ago we were playing Apex and he said it felt like his game were freezing / lagging a bit, then he got kicked out of the game completely. (He just got new internet that day so we thought that was the issue)
PC was still running as we were speaking on discord - I noticed when we spoke though sometimes it did freeze out from his end.
He said he was gonna restart his PC just to see if that helps, and mentioned it says there is an update also, so may take a few minutes.
PC restarted at went straight to a blue screen
Stop code: 0xc000021a
Startup repair log file: c:\windows\system32\logfiles\srt\srttrail.txt
I talked him through some potential fixes from online and youtube but nothing helped, so he ultimately just did a clean install of windows 10.
He's not tried any gaming yet, which I've asked him to do today. The machine formatted ok, logs into windows etc, so that seems fine
Whats happening though is, when he turns the machine off, it's making a weird noise, and the only way to really describe it like a stuttering noise coming from what he thinks is near the power supply. (Cant confirm)
Problem is, he's told me that he regularly turns off the PC by just holding down the power button, so I'm thinking he's messed up the PSU.
Is there anyway of running any tests on the PSU. Before this blue screen, no noises were coming from anywhere.
Without seeing the machine yet (going round tomorrow) I'm thinking if the PSU is now finding it hard to send enough power that could have caused the PC to lag and stutter (The PSU is more then enough for his machine)
Thanks
https://linustechtips.com/topic/1091335-potential-power-supply-problem/
This shouldn't cause damage to the power supply at all, more likely it just corrupts windows installs. To verify if the noise is the PSU, it's a good idea to remove the PSU from the case to separate it from the rest of the PC to hear it better, make sure the noise is actually coming from it.
Primary PC:
PSU tier list
How many watts do I need?
This Blue Screen happens when your Windows is corrupted it has nothing to do with the PSU.
Is it like a loud "click"? because if so that's just that Newer PSUs do this because you have a relay that essentially switches power from the +5VSB to the normal +5V between the off and on modes of the PSU.
It's normal behavior.
Personal Desktop":
Luna, the temporary Desktop:
1. Don't judge PSU by its wattage.
2. It is unlikely for PSU to not send enough power (which can be monitored with wall meter by the way).
Stuttering noise could be the fan hitting something.
Ex-EX build: Liquidfy C+... R.I.P.
Ex-build:
Meshify C – sold
Ryzen 5 1600x @4.0 GHz/1.4V – sold
Gigabyte X370 Aorus Gaming K7 – sold
Corsair Vengeance LPX 2x8 GB @3200 Mhz – sold
Alpenfoehn Brocken 3 Black Edition – it's somewhere
Sapphire Vega 56 Pulse – ded
Intel SSD 660p 1TB – sold
be Quiet! Straight Power 11 750w – sold
