I am building my first gaming pc and it won't turn on. There was a slight clicking noise coming from the PSU, so I called corsair and they said it was a capacitor problem so I returned it and bought a new one. I plug everything in and turn it on. Again same clicking noise but it did not start. What should I do also specs are below.
Core i7 9700k
Gigabyte RTX 2080
MSI 2390M Gaming MOBO
32 GB corsair RGB ram
Corsair 850w RM850x
PLEASE HELP
https://linustechtips.com/topic/1091112-help-me-please/
Core i7 9700k
Gigabyte RTX 2080
Corsair 850w RM850x
PLEASE HELP
Try taking everything out and just plug in the motherboard power and see if it receives power (if there are any LEDs on it). And check to see if your motherboard is mounted correctly, maybe the back of your case could be shorting the motherboard? Also, this is a person that seems to have a similar problem to yours...go through what he was told to see if that may resolve your issue. https://forums.whirlpool.net.au/archive/1768217
https://linustechtips.com/topic/1091112-help-me-please/#findComment-12785244
Google : Breadboarding a PC and follow the instructions
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
https://linustechtips.com/topic/1091112-help-me-please/#findComment-12785289
Core i7 9700k
Gigabyte RTX 2080
Corsair 850w RM850x
PLEASE HELP
It doesn't show are you using HDD or SSD ?  I know stupid question but we gotta know as clicking noise means hard drive.  A mobo can't make a sound,  Only fans can make bad noises or in your case it is coming from the PSU but you changed that and still nothing.  Try what ItsHarox said.  The click sound only leads me to HDD,  Fans doint even make a click sound so I don't know,, let see if we can help your further and what not.
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
https://linustechtips.com/topic/1091112-help-me-please/#findComment-12785300
I am using a 500gb m.2 from samsung. I think my mobo is defective causing the psu to short
https://linustechtips.com/topic/1091112-help-me-please/#findComment-12785416
I think so as well my friend, I'm sorry for this.  You can keep troubleshooting if you want and we see what happens.
https://linustechtips.com/topic/1091112-help-me-please/#findComment-12785423
I googled it and did it. Nothing... As I said I think it is the mobo shorting the psu. Is this possible?
Anything can be possible, just ensure you don't have the mobo on anything but cardboard so its not shorting touching a solder point on metal and its likely the mobo since you have 4 sticks of ram to try etc.  Do you have another computer you can hook the PSU up to?
https://linustechtips.com/topic/1091112-help-me-please/#findComment-12785425
@lukeMurray2311 or just use the jumper method to turn on the PSU with nothing hooked to it to ensure the PSU works as well
https://linustechtips.com/topic/1091112-help-me-please/#findComment-12785428
26 minutes ago, lukeMurray2311 said:
Oh well I have a new PSU and mobo coming tomorrow so ill try and see if that works
No kidding that sounds great.  :)
https://linustechtips.com/topic/1091112-help-me-please/#findComment-12785485
thanks for the help?
Just take your time installing everything a lot shouldn't take more then 30 minutes or so.  You seem technical person so no sweat..... I and we at LTT wanna hear what happens with this so keep us up to date and what not.
https://linustechtips.com/topic/1091112-help-me-please/#findComment-12785496
Thanks for helping finally built it today and it works great even did a mild overclock on the 2080
https://linustechtips.com/topic/1091112-help-me-please/#findComment-12795093
