Hey, it's my first time being around here but I needed some help on my computer. I have put all the components of the computer in one area but I'm not sure if its good or not, I'm basically new to everything in general. I plan on using this computer for gaming, editing, and some photoshop. Basically a lot of stuff.
All I need is some advice on what I should do.
https://ca.pcpartpicker.com/list/t4RMJ8
I also do plan on switching the case (since I don't like it that much) but please give me your opinions and stuff like that and things I should switch.
https://linustechtips.com/topic/1091098-first-time-building-a-computer-need-help/
More storage is a must. 500gb will fill up quickly. I'd also try to find a better GPU, which may require a beefier power supply. I picked up an RTX 2070 for about 40 dollars more than the GPU you have on that list, however I did get an excellent deal on it.
I'll recommend the following changes..
PCPartPicker Part List
CPU: AMD Ryzen 7 3700X 3.6 GHz 8-Core Processor  ($433.50 @ Vuugo)
CPU Cooler: Cooler Master Hyper 212 Black Edition 42 CFM CPU Cooler  ($44.75 @ Vuugo)
Motherboard: Asus TUF GAMING X570-PLUS (WI-FI) ATX AM4 Motherboard  ($259.00 @ Canada Computers)
Memory: Crucial Ballistix Sport LT 16 GB (2 x 8 GB) DDR4-3200 Memory  ($96.99 @ Amazon Canada)
Storage: HP EX920 512 GB M.2-2280 NVME Solid State Drive  ($84.99 @ Newegg Canada)
Video Card: Gigabyte GeForce GTX 1660 Ti 6 GB OC Video Card  ($356.99 @ Amazon Canada)
Case: Fractal Design Meshify C ATX Mid Tower Case  ($119.99 @ Amazon Canada)
Power Supply: Corsair TXM Gold 550 W 80+ Gold Certified Semi-modular ATX Power Supply  ($89.99 @ Amazon Canada)
Total: $1486.20
Generated by PCPartPicker 2019-08-07 01:12 EDT-0400
You can even fit a 5700xt in that budget..
Motherboard: Asus PRIME X570-P ATX AM4 Motherboard  ($219.00 @ Canada Computers)
Video Card: XFX Radeon RX 5700 XT 8 GB Video Card  ($519.99 @ Memory Express)
Case: Fractal Design Focus G ATX Mid Tower Case  ($61.00 @ Newegg Canada)
Total: $1505.46
Generated by PCPartPicker 2019-08-07 01:18 EDT-0400
SSD TIER LIST
CPU - Ryzen 7 3700X
Mobo - ASRock X470 Taichi
Memory - G.Skill Trident Z RGB (8x2 3200MHz)
Storage - Sabrent Rocket 1TB - Seagate Barracuda 2TBWD Black 1TB
GPU - MSI GeForce GTX 980Ti LIGHTNING
CaseFractal Design Meshify C
PSUSuper Flower Leadex II Gold 650W
OP is located in Canada. RTX 2070 costs around $600 there.
SSD TIER LIST
CPU - Ryzen 7 3700X
