tech help
Solved by For Science!,
5 minutes ago, harvey likes intel said:i already have fans connected to the aio its the ones used as case fans
oh sorry I didn't read it properly. You just need to get around your BIOS, or if you want a "quick" but not free way, then get a powered 4-pin splitter so that you can add more fans to your AIO fan headers.
Ishikudeska ·
Xxu ·
4
Issac Zachary ·
Posted in Troubleshooting5 -
4
PopsicleHustler ·
Posted in Audio4 -
4
play_circle_filled
Latest From ShortCircuit:
