I have a asus tuf fx505gm with (Gtx 1060 6G) and core i7 8750h with turbo boost 3.9 GHz but with high temps it reaches 98° some times i turnd off turbo bost after installing a registry file and now it run on bese speed 2.2 GHz but i had a big preformens drop in games is there any way to limit the turbo boost speed like make it 3.4GHz
https://linustechtips.com/topic/1090539-control-cpu-frequency/
You could download intel XTU and try undervolting the laptop.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/1090539-control-cpu-frequency/#findComment-12779808
2 minutes ago, MoBH said:
I tried undervolting but i had the same result i also tried coling pad but notheing ?
Sadly, you likely just need to deal with the heat. Laptops are designed around this and operate differently in that regards than desktops do in terms of cooling and what to expect. Hell, my work laptop regularly hits 100c when just opening applications up.
Community Standards
"Beast Mode"
https://linustechtips.com/topic/1090539-control-cpu-frequency/#findComment-12779821
That model has bad cooling, you should avoid it at the first place
Anyway, you can lower down turbo ratio limits with Throttlestop (FIVR). Also please do undervolting
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
https://linustechtips.com/topic/1090539-control-cpu-frequency/#findComment-12782913
