So with the new ryzen 3rd gen cpus. I made some adjustments to my old list what do you guys think. And if you would make any improvements my budget is no more than $1700. And i live in santa ana if there is any shipping cost.
https://linustechtips.com/topic/1090406-updated-build/
Case?
Also, 120GB for a boot drive will go quickly.
Screwdriver specs: Long, pointy. Turns things. Some kind of metal.
Main rig:
i9-7900x | Asus X299-Prime | 4x8GB G-Skill TridentZ @3300MHz | Samsung 970 Evo 500GB | Intel 5400S 1TB | Corsair HX1200
unRAID server:
Xeon  E5-1630v4 |  Asus X99-E WS | 4x8GB G-Skill DDR4 @2400MHz | Samsung 960 EVO 250GB cache drive | 12TB spinning rust | Corsair RM750X
FreeNAS server:
AMD something-or-other | Asus prebuilt sadness | 8GB DDR3-1600 | 9TB magnetic storage | Potential fire threat
HTPC:
i7-4790 | GTX1650 | Dell Sadness | 12GB DDR3-1600 | Samsung 860 250GB | 1TB magnetic storage | James Loudspeaker SPL3 x2 | Corsair SF450
https://linustechtips.com/topic/1090406-updated-build/#findComment-12779166
Do you need a 3800X?  Oddly, no one recommends them that I have seen.  3700X for gaming/streaming, or 3600 for gaming.
250GB boot drive, 120 is too small.  Besides, why get an NVMe boot drive when all your data will be loading off a slow HDD?
Motherboards over $300 are ridiculous.
I guess I should ask what this machine will be used for?  I looked at your other build post from April, which you seem to be referencing, but you asked about a build then never responded to people who helped you.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1090406-updated-build/#findComment-12779189
Either go with 3700x or 3900x. No point in going with a 3800x. Just a marginal improvement over 3700x.
It seems that you love RGB. Here's a RGB build for you.
PCPartPicker Part List
CPU: AMD Ryzen 7 3700X 3.6 GHz 8-Core Processor  ($329.00 @ B&H)
CPU Cooler: Cooler Master MasterLiquid ML360R RGB 66.7 CFM Liquid CPU Cooler  ($129.99 @ Newegg)
Motherboard: Asus TUF GAMING X570-PLUS (WI-FI) ATX AM4 Motherboard  ($199.99 @ B&H)
Memory: Team T-Force Delta RGB 16 GB (2 x 8 GB) DDR4-3200 Memory  ($79.99 @ Newegg)
Storage: HP EX900 500 GB M.2-2280 NVME Solid State Drive  ($57.99 @ Newegg)
Storage: Hitachi Ultrastar 7K3000 3 TB 3.5" 7200RPM Internal Hard Drive  ($52.23 @ Amazon)
Video Card: ASRock Radeon RX 5700 XT 8 GB Video Card  ($384.99 @ B&H)
Case: Fractal Design Meshify C ATX Mid Tower Case  ($83.99 @ Walmart)
Power Supply: Corsair TXM Gold 650 W 80+ Gold Certified Semi-modular ATX Power Supply  ($69.99 @ Newegg)
Total: $1388.16
Generated by PCPartPicker 2019-08-05 00:03 EDT-0400
SSD TIER LIST
CPU - Ryzen 7 3700X
Mobo - ASRock X470 Taichi
Memory - G.Skill Trident Z RGB (8x2 3200MHz)
Storage - Sabrent Rocket 1TB - Seagate Barracuda 2TBWD Black 1TB
GPU - MSI GeForce GTX 980Ti LIGHTNING
CaseFractal Design Meshify C
PSUSuper Flower Leadex II Gold 650W
https://linustechtips.com/topic/1090406-updated-build/#findComment-12779207
Total: $1388.16
Thanks for everything
https://linustechtips.com/topic/1090406-updated-build/#findComment-12779316
Total: $1388.16
Go full RGB or go home :P
Gaming Pro Carbon MOBO and a Cooler Master H500 or MB511 ;)
Also the only spot that 360mm Radiator will fit in the Meshify C is in the Front. Either case listed plus a 240mm = 3 RGB fans in front, 240mm RGB radiator on top :) Very full look.
https://linustechtips.com/topic/1090406-updated-build/#findComment-12779580
SSD TIER LIST
CPU - Ryzen 7 3700X
https://linustechtips.com/topic/1090406-updated-build/#findComment-12779722
