Upgrading my system.
Go to solution Solved by 5x5,
1 minute ago, HELPPLS said:
Any bottlenecking with the i5 7500?
Lots but that's normal. It's an i5 quad-core.
Hi guys I just finished my summer job and have like 500 dollars, and was going to use it to upgrade my computer. I am looking at replacing the gt 730 with either a rx 5700 xt or rtx 2060. Will there be a bottle neck?
PS:I am going to get the open air cooler design for the rx 5700 xt sometime August.
Specs:
16gb ddr4
i5-7500 at 3.4GHZ
gt 730 2gb
https://linustechtips.com/topic/1090260-upgrading-my-system/
Sell the i5 and 730 get a Ryzen 1600
https://linustechtips.com/topic/1090260-upgrading-my-system/#findComment-12777970
I think so. It will be a great jump from 730.
If you plan to buy Ryzen, don't worry about it, just use what you have.
https://linustechtips.com/topic/1090260-upgrading-my-system/#findComment-12777980
Just now, HELPPLS said:
I have an 850 watt evga powersupply is that good enough? How much does the rx 5800xt.
It will run on a 550 watt psu.
https://linustechtips.com/topic/1090260-upgrading-my-system/#findComment-12777983
I've built a few budget systems with that i5 6500/7500 chip, and its a decent part - I wouldn't go upgrading it to a 9900K tomorrow if I still had it.
I wouldn't really thing twice about tossing in a 1070 or 2060 Super into that build, then upgrading to a newer i5/i7 later when you've got more coin to toss at it. It'll be a very solid PC IMO. The 2060 dropped to 290 this week so it leaves you room to buy a good PSU or good SSD if you need it.
I'm not touching AMD until the 3rd party cards come out, those blower coolers are running very hot right now.
https://linustechtips.com/topic/1090260-upgrading-my-system/#findComment-12778187
