I have a Corsair CX550M power supply that is 80+ Bronze certified. I have had problems with this power supply (I'm on my third power supply of this variant now) in that the fan would make a lot of noise, like it was hitting the grill or osmething inside, so I'm used to it having problems. My current one has gone on for about one and a half years without problems, powering my OC Ryzen 5 1600 (3.8GHz @ 1.325V (I think)) and a 1060 6GB.
I decided to get an EVGA 2080 super XC, but when I plugged it into my system and started up a CSGO FPS benchmark, I heard a really loud and concerning whine coming from where the PSU cables connect to the GPU. Is this because the PSU can't handle the 2080s, or that there is something wrong with the card?
Questions welcome to get to a solution.
https://linustechtips.com/topic/1089907-cable-whine/
cables dont really make noise, its either the VRM or the PSU thats making that noise. Seeing as you used CS:GO i wouldnt be surprised if its not both
Builds:
https://linustechtips.com/topic/1089907-cable-whine/#findComment-12775032
It didn't sound like it was coming from the VRMs though, just where the power connectors are. Could there be something there that could be causing the whine?
I also think it's good to mention that it didn't sound like typical coil whine, as it seemed way too loud to me, louder than anything else in my system.
Could I still run the 2080s safely even with that noise?
https://linustechtips.com/topic/1089907-cable-whine/#findComment-12775042
39 minutes ago, LukeSavenije said:
oh, i already know what's happening here
dual forward and 2080
it's a general issue with the cx550m and about any dual forward
Could you explain what "dual forward" means, and if it is a problem and shouldn't run my 2080 on the PSU?
https://linustechtips.com/topic/1089907-cable-whine/#findComment-12775164
dual forward is a topology used mainly on older dc-dc regulated PSUs. it's mostly been replaced, and is in place of the cxm and vs, but has been replaced in the others
what it means for you (and actually for me as well) is that it starts to whine under higher loads with high end gpus (1070+). the only thing you can really do about it is to replace the unit by something higher end like a txm (to compare it inside the same company)
https://linustechtips.com/topic/1089907-cable-whine/#findComment-12775181
So I should be fine if I run the 2080, and I dont have to worry about damage to the card/psu/any other component connected to the PSU?
https://linustechtips.com/topic/1089907-cable-whine/#findComment-12775193
