Hello, I am just wondering if anyone can see any problems/improvements to this build my budget is around $700 and can't particularly move from that point. I believe that all of the parts which I have chosen will fit into the case and the fans will aswell. I would rather retain the mini ATX case due to the portability of it. the power supply is another worry of mine due to it being so close to the estimated wattage.IF you have any questions about the build or anything else I will attempt to answer back as soon as possible.
PC PartPicker List
Many thanks, Ryan.
https://linustechtips.com/topic/1089838-700-gaming-pc-help/
use UK pcpartpicker since you're in the united kingdom.
https://linustechtips.com/topic/1089838-700-gaming-pc-help/#findComment-12774525
Skip the cooler, ditch the fans and upgrade to a 1660Ti.
Why are you using dollars if you're in the UK?
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/1089838-700-gaming-pc-help/#findComment-12774532
I'll recommend something like this instead...
PCPartPicker Part List
CPU: AMD Ryzen 5 2600 3.4 GHz 6-Core Processor  ($132.90 @ OutletPC)
Motherboard: ASRock B450M PRO4 Micro ATX AM4 Motherboard  ($69.89 @ OutletPC)
Memory: Team T-FORCE VULCAN Z 16 GB (2 x 8 GB) DDR4-3000 Memory  ($59.99 @ Newegg)
Storage: HP EX900 500 GB M.2-2280 NVME Solid State Drive  ($57.99 @ Newegg)
Video Card: Sapphire Radeon RX VEGA 56 8 GB PULSE Video Card  ($309.99 @ Amazon)
Case: Cooler Master MasterBox Q300L MicroATX Mini Tower Case  ($44.99 @ Walmart)
Power Supply: Thermaltake Toughpower Grand RGB 650 W 80+ Gold Certified Fully Modular ATX Power Supply  ($59.99 @ Best Buy)
Total: $735.74
Generated by PCPartPicker 2019-08-03 13:53 EDT-0400
SSD TIER LIST
CPU - Ryzen 7 3700X
Mobo - ASRock X470 Taichi
Memory - G.Skill Trident Z RGB (8x2 3200MHz)
Storage - Sabrent Rocket 1TB - Seagate Barracuda 2TBWD Black 1TB
GPU - MSI GeForce GTX 980Ti LIGHTNING
CaseFractal Design Meshify C
PSUSuper Flower Leadex II Gold 650W
https://linustechtips.com/topic/1089838-700-gaming-pc-help/#findComment-12775251
