So, turns out my 10+years old computer won't survive much longer.
I'll need a new build for Digital Painting, 3D modelling practices (still learning), casual 1080p Gaming, and casual audio production (USB Home Studio Devices).
Looking up most recent builds I came up with the following on my budget:
Motherboard: Gigabyte B450I Aorus Pro
Processor: Ryzen 5 3600
RAM: (2x8) 16GB DDR4 3000 CL16
Storage: M.2 Samsung 860 EVO 250Gb
Case: NZXT H200I
Total: USD 850,00
My Budget would be up to USD 1000,00 for these parts.
I could use from my old build:
-Corsair PSU 650W (don't recall the model, but it's an 80+ gold non-modular, 2 years use)
-2x HDDs (1TB and 2TB SATA)
-GPU Radeon HD 6950 (Will get replaced with an RTX 2060 later on around December)
-All Peripherals
The things I'm not confident about are the form factor and RAM.
I never built an ITX before, is it up to the task? Would I need better cooling?
As for RAM should I get 2x16 or higher speeds than 3000's?
Would be a better choice getting mATX and 4x4 or 4x8 kits?
Any better M.2 recommendations?
Is there any bottleneck? (Besides GPU, but I plan on upgrading later)
I don't plan on overclocking ever.
Thanks in advance :)
Edited by wkd
dyslexia
https://linustechtips.com/topic/1089526-help-on-new-build-itx/
Itx builds are usually pretty bad in terms of thermals, if it's going to be used heavily for gaming and 3d modeling I would suggest going for just a micro atx so you can pick up a little bit bigger of a case that has better thermals. ITX boards and cases are usually a little bit more expensive than their Micro ATX or ATX counterparts as well.
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
https://linustechtips.com/topic/1089526-help-on-new-build-itx/#findComment-12772050
I could adapt to a B450M Mortar and get more RAM sticks all on a bigger case with the same budget.
But I kinda wanted a small build as I already got a small room and table to work with.
Maybe add a Kraken X62 Cooler would help? It'll still be inside budget.
https://linustechtips.com/topic/1089526-help-on-new-build-itx/#findComment-12772083
If you have a $1000 budget, plus already have the PSU, HDDs, and  GPU to use until you decide to upgrade, you could do a bit better than a 3600. Here's two builds one is MATX and the other ITX, both great builds, the MATX is a bit more budget friendly and the meshify C is one of the best cases on the market for thermals. Also if you went for the MATX build you can throw an RTX 2060 in it for only like $300 more so with a new RTX 2060 in the build as well it only brings you up to like $1100ish.
PCPartPicker Part List
Type Item Price
CPU AMD Ryzen 7 3700X 3.6 GHz 8-Core Processor $329.99 @ Newegg
Motherboard ASRock X570M Pro4 Micro ATX AM4 Motherboard $174.99 @ Newegg
Memory Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3200 Memory $84.99 @ Amazon
Storage HP EX920 1 TB M.2-2280 NVME Solid State Drive $109.99 @ Newegg
Case Fractal Design Meshify C Mini MicroATX Mini Tower Case $83.99 @ Amazon
  Prices include shipping, taxes, rebates, and discounts
  Total (before mail-in rebates) $793.95
  Mail-in rebates -$10.00
  Total $783.95
  Generated by PCPartPicker 2019-08-02 11:34 EDT-0400
https://linustechtips.com/topic/1089526-help-on-new-build-itx/#findComment-12772085
with that case you will be just fine, but the 2060 must be 2 slots tall, there is not much space on that area where gou goes so air flows well
looks good to me, look at this video about a build inside that case, is a long review
build in that case is the same as build in the h500, but h500 has even less restrictions
consider moving to a micro or atx form factor if size is not a limitation, but a itx on that case is easy to do, perfectly viable
https://linustechtips.com/topic/1089526-help-on-new-build-itx/#findComment-12772087
scratch the 860 m.2 for a 970.  Ryzen 5 2600 is reasonably priced.  Check the qualified vendor list (QVL) for compatible memory.  32G is overkill. 2X8 would be fine IMHO.  The case has good features.  You only have 1 3.5 bay for the other drives unless they are ssd's or 2.5 laptop drives. Other than that, it will be a nice machine.
https://linustechtips.com/topic/1089526-help-on-new-build-itx/#findComment-12772114
Hey guys, decided to go with the X570 ITX Build
Motherboard: Gigabyte X570 I Aorus Pro
Processor: Ryzen 7 3700X
RAM: (2x8) 16GB DDR4-3200 CL16
Storage: M.2 Samsung 970 EVO 250Gb
Case: NZXT H200I
Got an NZXT Kraken X52 to tackle the heating problem a bit for just 50 bucks over the budget.
And now that I have the power for it, I might consider overclocking a bit. Seems like a waste not to.
As for the GPU, any particular brands I should keep an eye out? (RTX 2060)
Thanks for the tips and may the Force be with you. :)
https://linustechtips.com/topic/1089526-help-on-new-build-itx/#findComment-12782127
There you go mate...
Added in a Radeon 5700xt, it's much better that rtx 2060.
CPU: AMD Ryzen 7 3700X 3.6 GHz 8-Core Processor  ($329.99 @ Newegg)
Motherboard: MSI B450M GAMING PLUS Micro ATX AM4 Motherboard  ($84.99 @ Amazon)
Memory: G.Skill Ripjaws V Series 16 GB (2 x 8 GB) DDR4-3200 Memory  ($67.99 @ Newegg)
Storage: Intel 660p Series 1.02 TB M.2-2280 NVME Solid State Drive  ($94.99 @ Amazon)
Video Card: ASRock Radeon RX 5700 XT 8 GB Video Card  ($384.99 @ B&H)
Case: Cooler Master MasterBox Q300L MicroATX Mini Tower Case  ($44.99 @ Walmart)
Total: $1007.94
Generated by PCPartPicker 2019-08-05 23:28 EDT-0400
SSD TIER LIST
CPU - Ryzen 7 3700X
Mobo - ASRock X470 Taichi
Memory - G.Skill Trident Z RGB (8x2 3200MHz)
Storage - Sabrent Rocket 1TB - Seagate Barracuda 2TBWD Black 1TB
GPU - MSI GeForce GTX 980Ti LIGHTNING
CaseFractal Design Meshify C
PSUSuper Flower Leadex II Gold 650W
https://linustechtips.com/topic/1089526-help-on-new-build-itx/#findComment-12782570
There you go mate..
I found these builds in Pinterest, to convince you to proceed your build further. Don't worry, it can even take NH-D15 the whole unit with its chromax covers, should be a cool inside cool outside build.
SILVER GLINT
CPU: AMD Ryzen 7 3700X || Motherboard: Gigabyte X570 I Aorus Pro WiFi || Memory: G.Skill Trident Z Neo 3600 MHz || GPU: Sapphire Radeon RX 5700 XT || Storage: Intel 660P Series || PSU: Corsair SF600 Platinum || Case: Phanteks Evolv Shift TG Modded || Cooling: EKWB ZMT Tubing, Velocity Strike RGB, Vector RX 5700 +XT Special Edition, EK-Quantum Kinetic FLT 120 DDC, and EK Fittings || Fans: Noctua NF-F12 (2x), NF-A14, NF-A12x15
https://linustechtips.com/topic/1089526-help-on-new-build-itx/#findComment-12783087
