Are there any fan hubs out there that let you manually adjust the speed of all fans attached? I don't want anything complicated like usb or pcie connections, just something simple like a dial or slider that controls the fan voltage.
CPU: Ryzen 5 5600x  | GPU: GTX 1070 FE | RAM: TridentZ 16GB 3200MHz | Motherboard: Gigabyte B450 Aorus M | PSU: EVGA 650 B3 | STORAGE: Boot drive: Crucial MX500 1TB, Secondary drive: WD Blue 1TB hdd | CASE: Phanteks P350x | OS: Windows 10 | Monitor: Main: ASUS VP249QGR 144Hz, Secondary: Dell E2014h 1600x900
https://linustechtips.com/topic/1089481-variable-fan-speed-hub/
https://linustechtips.com/topic/1089481-variable-fan-speed-hub/#findComment-12771726
