Hey guys! So I get to discover that mu Audio isn't working on my PC. (old one). So, i thought it might be the speakers so, I tried to put my speakers (Creative 245) into another PC and check if it's speakers problem or not. But, it works well in other pc's. so, this isn't the speaker. Then I put another Computers speakers into my old computer and that too doesn't work. So it's definitely the Audio ports. I'm currently downloading Updates though I'm updated till now. What could be the problem? I will tell you guys what happens after the update. Please help me! Can't do much without audio :(
 [spoiler=CORMAC]CPU:Intel celeron 1.6ghz RAM:Kingston 400mhz 1.99gb MOBO:MSI G31TM-P21 GPU:Will add one later on! CASE:local ROUTER D-Link 2750U, D-LINK 2730U MOUSE:HP,DELL,ViP KEYBOARD: v7 SPEAKERS:Creative 245  MONITOR:AOC E970Sw HEADSET: Sony MDRx05s UPS:conex ups avr 500va PSU:idk OD:Samsung super writemaster STORAGE:80 gb seagate+ Seagate 1TB OS:Windows xp sp3 themed to Windows 7 + Linux |Rest all pc in my house will be updated from time-time
COMING SOON
https://linustechtips.com/topic/108935-audio-ports-not-working/
Hey, it's possibly drivers not being installed. Which audio ports are you talking about, the ones at the back on the motherboard?
Elven
Corsair 400R, i7 3770K @ 4.5GHz 16GB, Corsair Vengeance 1600MHz, Gigabyte Z77X-UD5H Motherboard, 240GB Samsung 840 Evo Sata III SSD, 2 x Asus GTX 780 Direct CU2 SLI, Corsair H100i and Corsair AX860i Platinum Power supply.
https://linustechtips.com/topic/108935-audio-ports-not-working/#findComment-1455879
Elven
Yep, the rear panel one. And what do you mean by they're not installed? All these days, even today, I've played games and listened to music. Let me make this clear to everyone:
Today afternoon I came and started the PC and browsed the Internet and listened to some songs. Then, I go to study and my bro comes and sits on the PC. I said go and play on other PC. He says:No, I want this PC because I have to play Some games. I said: You can play it on any other computer!. Then I said: F'ck! I'm late for my classes. So, I went. But, while going, I heard the noises of the game Rise of Nations. My bro was playing till I came back. Then I stopped the game and then the PC is freezed. So, I restarted it and then Suddenly, the voice isn't there!
COMING SOON
https://linustechtips.com/topic/108935-audio-ports-not-working/#findComment-1455910
Check any audio "control panel" that may have come with the motherboard to see if the audio jacks are re-configurable. It may be that the usual audio out port (green) has accidentally been configured as a mic port or rear channel port, etc.
A sieve may not hold water, but it will hold another sieve.
i5-6600, 16Gigs, ITX Corsair 250D, R9 390, 120Gig M.2 boot, 500Gig SATA SSD, no HDD
https://linustechtips.com/topic/108935-audio-ports-not-working/#findComment-1455930
Well, I get this when I plug my Speaker in the Green audio port.
http://imgur.com/V7ncJUg
COMING SOON
https://linustechtips.com/topic/108935-audio-ports-not-working/#findComment-1455989
Ok, try to go through these quick steps to check nothing stupid happened like your audio device being unselected.
http://www.tinyeye.com/avsetup/soundsetup_xp.html#1
Next, follow these steps to find device manager on XP
http://pcsupport.about.com/od/windowsxp/ht/accessdmcpnxp.htm
Now right click on your sound device and select update drivers. If this doesn't work then manually download the drivers for it. Now right click and un-install them. Restart computer and re-install.
https://linustechtips.com/topic/108935-audio-ports-not-working/#findComment-1456193
