Rgb problems
Solved by W-L,
On 7/31/2019 at 3:15 AM, HIBIKI the Gamer said:Im planning to buy the bitfenix argb 3.0 strip and there is no much reviews about the strip my problem is does the strip can be daisy chain because i see the imgaes it has some sort of cap or cover on the strip
Welcome to the Forums!
It covers pins on the end which allow for the LED strip to be extended.
