Hello i would really want a balls to the wall pc and i think i found some pretty bang for the buck items heres the list
+ an MSI Optix MAG271CQR monitor.
please let me know if this is good for the money or if i'm bad at doing this :))))
btw this is 2 938 where i live
https://linustechtips.com/topic/1088009-help-with-pc/
Where do you live?  Why not use a region basis on PC Part Picker?
AMD has a more balls to the wall setup. The 9700K + 2070 isn't a balls to the wall level machine anymore.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1088009-help-with-pc/#findComment-12760334
Depends on what he plans to run. This setup is perfect for high framerate FPS gaming. Considering he's got a 1440p 144Hz freesync/g-syng compatible monitor on there, I guess that's where he's going. And in this situation, a setup with the 9700K  at 5.1GHz can still run circles around a 3900X build.
Desktop:     Core i7-9700K @ 5.1GHz all-core = ASRock Z390 Taichi Ultimate = 16GB HyperX Predator DDR4 @ 3600MHz = Asus ROG Strix 3060ti (non LHR) = Samsung 970 EVO 500GB M.2 SSD = ASUS PG279Q
Notebook:  Clevo P651RG-G = Core i7 6820HK = 16GB HyperX Impact DDR4 2133MHz = GTX 980M = 1080p IPS G-Sync = Samsung SM951 256GB M.2 SSD + Samsung 850 Pro 256GB SSD
https://linustechtips.com/topic/1088009-help-with-pc/#findComment-12760384
Yeah, it's mid-high end.
I guess I just define balls to the wall differently.
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1088009-help-with-pc/#findComment-12760400
No? Which planet do you live on? The 9700K needs 5GHz to compensate for its lower IPC compared to Zen2 - not to mention that it's still barely 4-5% faster in some games and loses in others to even a 3700X - and at 1440p, the 9700K basically loses in every scenario to a 3700X since the GPU becomes the bottleneck. Please stop spreading wrong information.
https://linustechtips.com/topic/1088009-help-with-pc/#findComment-12760419
I'm not? If you check most sources that have benchmarked the ryzen 3000 chips against 9700k / 9900k overclocked, then literally 90% of games will hit 5-10% higher framerates on Intel. With that AIO he should be able to hit a solid 5GHz if not 5.1GHz on that CPU easily.
Sure, GPU wise I can't really argue... then again even at 1440p, a 2070 will run most competitive FPS titles at 144Hz no sweat, unless you absolutely need your ultra graphics. Even my old 1070 maintains a solid 165Hz in Overwatch, Fortnite, Apex, etc... at medium to high settings.
https://linustechtips.com/topic/1088009-help-with-pc/#findComment-12760468
Thing is - that's at 1080p with 400$ boards that can handle the 200W that the 9th gen CPUs pull above 5GHz - with his board, I'd say 4.9-5 is what he can hope for - its VRMs are mediocre. ANd at 1440p, the 3700X and 9700K will game the same but for anything else, the 3700X is about 30% faster due to SMT.
https://linustechtips.com/topic/1088009-help-with-pc/#findComment-12760477
Let's agree to disagree and leave it there :P
https://linustechtips.com/topic/1088009-help-with-pc/#findComment-12760491
So you’re saying if he gets the 2070 and runs it at 1440p and 144hz it will be good but If at ultra settings it will be kinda bad? Another statement if choosing the 2070 super will it improve and make it better and running ultra or even the 2080 will that help it.
very interested in this conversation
https://linustechtips.com/topic/1088009-help-with-pc/#findComment-12763282
Where did you get that info from ? The Gigabyte Z390 Aorus boards have rock solid VRM's. Even the entry level Z390 UD can handle a 9900K with a decent overclock. Any of the Aorus boards can handle 5GHz+ on a 9900K.
I would agree that Ryzen is the way to go though.
https://linustechtips.com/topic/1088009-help-with-pc/#findComment-12763726
Local reviewers (HWBG to be specific) did some testing - a lot of Z370 and Z390 boards have trouble sustaining performance for long periods - the thermals tend to enter a runaway scenario after an hour or two since the cooling potential of the heatsinks is not enough. The result is clockspeeds going down rapidly to about 4.2-4.4 on the i7/i9s
https://linustechtips.com/topic/1088009-help-with-pc/#findComment-12763733
The heatsink is kind of irrelevant though if you have a good enough VRM in the first place. A crap VRM can be made better by slapping a huge heatsink on it. A solid or overkill VRM can basically run with a lesser or even no heatsink i.e The Z390 Aorus Xtreme could handle a 9900K even if you removed the heatsink.
Review below has a 9900K at 5.2GHz on an Z390 Aorus Pro. The VRM coped fine.
https://www.tweaktown.com/reviews/8833/gigabyte-z390-aorus-pro-intel-motherboard-review/index7.html
Also go and watch Buildzoid on Youtube as he goes over Gigabyte Z390 boards and the VRM.
https://linustechtips.com/topic/1088009-help-with-pc/#findComment-12763773
On 7/30/2019 at 12:31 AM, Kurikaeshi said:
I'll recommend something like this instead...
PCPartPicker Part List
CPU: AMD Ryzen 7 3700X 3.6 GHz 8-Core Processor  ($329.00 @ B&H)
CPU Cooler: Noctua NH-D15 82.5 CFM CPU Cooler  ($89.95 @ Amazon)
Motherboard: Asus TUF GAMING X570-PLUS (WI-FI) ATX AM4 Motherboard  ($199.99 @ B&H)
Memory: G.Skill Ripjaws V 16 GB (2 x 8 GB) DDR4-3600 Memory  ($77.99 @ Newegg)
Storage: Intel 660p Series 2.048 TB M.2-2280 Solid State Drive  ($181.89 @ OutletPC)
Video Card: EVGA GeForce RTX 2080 SUPER 8 GB BLACK GAMING Video Card  ($723.98 @ Newegg)
Case: Fractal Design Meshify C ATX Mid Tower Case  ($83.99 @ Amazon)
Power Supply: BitFenix Formula Gold 650 W 80+ Gold Certified ATX Power Supply  ($75.99 @ SuperBiiz)
Operating System: Microsoft Windows 10 Home OEM 64-bit  ($106.99 @ Other World Computing)
Keyboard: Corsair K68 Wired Gaming Keyboard  ($61.74 @ Amazon)
Mouse: Logitech G502 Proteus Spectrum Wired Optical Mouse  ($34.99 @ Amazon)
Total: $1966.50
Generated by PCPartPicker 2019-07-31 06:56 EDT-0400
SSD TIER LIST
CPU - Ryzen 7 3700X
Mobo - ASRock X470 Taichi
Memory - G.Skill Trident Z RGB (8x2 3200MHz)
Storage - Sabrent Rocket 1TB - Seagate Barracuda 2TBWD Black 1TB
GPU - MSI GeForce GTX 980Ti LIGHTNING
CaseFractal Design Meshify C
PSUSuper Flower Leadex II Gold 650W
https://linustechtips.com/topic/1088009-help-with-pc/#findComment-12765217
Of course? If you have the budget to splurge, a better graphics card will get you better performance, that's a given.
However it all depends on the games you play and your budget. Do you want to play beautiful RPG's at 4K with ultra settings at 30fps? You're better off investing in a high-end graphics card and not to splurge on the CPU. Or do you want to play FPS titles in 1080p with high framerates? Invest in a high-end CPU and settle for a mid-range GPU.
Let's say you have $800 to spend on a CPU and GPU (let's ignore the rest of the system for the sake of simplification): at this budget you could either get a Ryzen 5 2600 with an RTX 2080 or you could get a Core i7 9700K with an RTX 2070. Both combinations are perfectly reasonable choices, they just serve another purpose.
https://linustechtips.com/topic/1088009-help-with-pc/#findComment-12774314
